This amp contains a veritable cornucopia of relays!
The ones dr.audio suggested you check on are RY301 and RY302. Just to clarify, since speaker relays are also being discussed at length, RY301 and RY302 are not speaker relays. RY301 appears to switch between fixed and variable inputs, and RY302 also does something input-ishMeanwhile the speaker relays are RY901 and RY902.
Which relays are the new relays from Germany meant to replace? Best to use schematic designators like RYnnn instead of or in addition to marked-up pics.
There's no bad place to start... It's a complex amp, but the cause of the fault you're experiencing is probably pretty simple. You'll get her fixed! You got this![]()
Noted on using the schematic designators, i will do that, thank you.This amp contains a veritable cornucopia of relays!
The ones dr.audio suggested you check on are RY301 and RY302. Just to clarify, since the speaker relays are also being discussed here, RY301 and RY302 are not speaker relays. RY301 appears to switch between fixed and variable inputs, and RY302 also does something input-ishMeanwhile the speaker relays are RY901 and RY902.
The relays purchased from Germany were purchased here: Sony Relays
Embarrassingly i dont know the answer to your question, i assumed a speaker relay was a speaker relay and it said it was for my amp model... i swear ive learned a lot in the weeks since...
the website doesn't give any specs that i can see but there is some nearly impossible to read writing on the new relays themselves seen here.
the part number for RY901 and RY902 is 1-515-676-11 in the service manual. These look to have a similar format/size but i do not know if the specs match.
Im also having trouble understanding how the giant metal covering for the large capacitors comes off and it needs to be removed for me to get at the board those relays are on. It had 6 screws that appeared to be fastening it to the chassis but once they were removed it still wont budge. Im having trouble finding video of anyone doing disassembly in that area of the amp and the service manual seems rather vague.
