The Fisher X100 - Right Channel Out
I'd cut the black wire under "F" and land the two ends of the Black wire on a terminal strip just like the one at "B" and "C" but put the new strip where "F" is located. Then you can attach the CL-80 to the two ends of the black wire on the ends of the new terminal strip. Just giving some ideas.
If you look at the X100 schematic that places the CL-80 between the fuse and the line side of the power transformer.
Thanks Tim. I’ll report back after I receive part and install.
One other thought.... Try to put the black part of the CL-80 away from other components and wire as much as practical. It generates a fair amount of heat. Mostly don't have it sitting on things that are heat sensitive.
