FlaCharlie
Yeah, the data sheet says each triode has an Rp of 1.3k. So with the load resistor figured in output impedance should be just over 1k.I banged one together using one triode per channel, it was still sufficiently low output impedance. I did the very lazy output impedance check method. Set the voltage to 2v p-p, load it down with a pot until it drops to 1v, measure the pot. Pot value = output impedance. Pretty sure I used a 2k pot and it ended up somewhere right around 1000 ohms.
I was contemplating LED bias just because I've never used that on anything. Free pilot light too.
As I said, I got a little nervous about them because two of the NOS ones I bought, from two different sellers, had shorts. The second one was purchased to replace the first one. Hopefully just a streak of bad luck.
I didn’t try LEDs on this project but I tried them on the 6SL7 when I had the Simplissimo amp breadboarded. Stephe uses them and likes them so I got some of the ones she recommends.
I immediately noticed an increase in detail. But very shortly, literally within 5 minutes, listening fatigue set in and my ears were hurting so I switched back to battery grid bias. So obviously, YMMV. Maybe you’ll like them. I always encourage experimentation.
