Updates updates updates!
I apologize for the frequent periods of radio silence, the project has continued non-stop, however life is life and I don't always have quite as much free time as I would like...
With that said, on to the fun stuff, though sadly no photos today. My updates for today center around two things: new boards and new end caps for the chassis
I'll start with the end caps, since there's not a whole lot to say. As you all may recall, my first of the two units I am currently rebuilding arrived sans the white metal end caps. As I prep to have the new PCBs made and do the final parts orders, I nearly forgot that this is an issue that I haven't yet settled on a solution for, or even really looked into yet, until today. As the second 'Zilla did arrive with the white end caps, I was able to whip up the simple design in CAD, and I am now in the process of seeking a shop to make some new ones, which is where all of you come in! Since I know at least one reader of this thread is in need of some new end caps (cough, Craig!
@llwhtt), and figure there may be others, and due to the fact that the price per piece becomes significantly cheaper to have made as quantity goes up, I would like to open this order up to the fine folks of AK! As I wish not to anger any of the very fine moderators, I will abstain from talk here that best belongs in another forum, however I will say that with just a little searching, should my order get up to at least 10 (so 5 sets of 2) then the piece price for bare metal shipped would be roughly 35 a pop (times 2 for a set brings it to around 70 a set), and would only go down from there. I am also looking into options for getting them painted or powder coated as well, in addition to me finally breaking out that HVLP paint rig I dropped a small fortune on earlier this year. If you're interested please PM me. (Dearest moderators, I solemnly swear that I have no intent of profiting, and that my ask is simply to gauge interest, as this was discussed earlier in the thread, I promise that once this becomes serious I will create a separate post in the appropriate forum!).
Now that we've got that out of the way, on to the PCBs I have been spending the bulk of my time on over the past two months. I promise there will be photos, or at least renderings soon to share, though I am admittedly a little hesitant to post, not for fear of them being stolen, but for fear of everyone thinking I have lost my mind based on what they see! I'll write more when I get some photos to show, but for now here are some highlights:
- 100% component symmetry (not including the TO-66s or the TO-3s as those I can't change while still allowing for a perfect swap out for original boards. Also not including the resistor for the LED or the board connector as it was my own addition to move them onto the board, and there's no point in duplicating them on the other side of the board) (also, at least 75-80% wiring symmetry, but more on that below)
- Was it worth the time, the effort, the years removed from my overall lifespan? Not a chance! Do I regret pursuing this goal? Not one bit.
- To explain, what I have done is to reconfigure the layout such that all components are symmetric for the two halves (technically whole, but you know what I mean) of the driver. So to answer the question that no one asked, yes, it absolutely is possible to lay out the circuit symmetrically (so there are a few tiny asterisks that belong here but I will explain those with the photos/partially below).
- If, at this point, you start wondering about whether or not it would be possible to implement the circuit such that you could additionally make the two driver boards symmetric, I can confirm that it is. I haven't done so in my design, because that's honestly where I draw the ridiculousness line, (not to mention another reason I will explain below,) but with one small modification to the wiring for the IC, my design could literally be flipped and it would not make a difference which side you place the components on.
- Zero jumpers
- So I am going to start by saying that yes, I designed the board to be 2-layered as opposed to one as the originals were, however:
- I only use the extra layer for ground wires (which conveniently allowed for what I think is pretty nifty star grounding)
- Simply to prove it to myself, I also created a version that exists entirely within one layer, and I can confirm that it is 100% possible. Yes, the entire circuit can be implemented, symmetrically, on a single side, without a single jumper. In fairness to the original designers of these boards though, the amount of trial and error and reconfiguration of the layout that I was able to do in a few weeks with modern software tools probably would have taken 5 years to do the old way. With that all said, I chose not to do everything in a single layer simply because it was far from the most elegant solution.
- Differential wiring
- Regardless of whether or not a particular signal was actually part of a differential pair, every signal that has a counterpart of the opposite polarity has been matched in length/width down to a precision that isn't even achievable by a board house manufacturing the PCBs, but why not? This is also a big part of why I didn't make my final (well, not technically final until I send it out to be made) design such that the boards can be flipped, since when I tried it, it became quickly apparent that electrically there is no difference anyway.
- Component selection
- This is mostly what I am worried about sharing, as many of you will undoubtedly look at the BOM and verbally/nonverbally exclaim "why? just why? seriously, why?". My response, of course, will be because why not?
- To explain, no, I didn't go too overboard (totally subjective), as in snake oil overboard (snake oil, oil filled several hundred dollar caps, tomato, tomAHto, not looking to debate), however I was extremely liberal in both my selection of premium parts, and in exercising creative license in the rating of parts selected. My selections will result in a way overbuilt driver that will never in a million years be capable of pushing them past their limits (silicon excluded, obviously), but there was method to my selections. In some cases there was a negligible price difference, or even in some cases it is cheaper to overspec things, but a lot of my selections were also made after carefully examining the ever-growing collection of stripped Ampzilla I driver boards I have, along with countless hours of internet searching. In short, if any of the boards I have, or any photos I could find, show a board that has clearly taken a beating from heat damage, I overspec.
Anyways, that's all for now, folks, stay tuned for photos to come!
