So throughout my listening tests so far I have been keeping a list of issues that arise, or additional things that need fixing. I'll start with the cooling fans.
First things first, the old fans had to go, they were both loud and dirty to the point where cleaning would be impractical or even destructive, and worst of all (in my mind, at least) they were different from each other (same make/model, different levels of noise) so I decided to replace the original boxer fans.
Although I did briefly consider retrofitting to use a DC cooling fan, I wanted to give AC fans a chance still, and so my first attempt at replacing with quieter fans was using AC powered fans powered by the secondary coil of the transformer.
Prior to purchasing the replacements shown installed above, I did a ton of research into the quietest AC fans available, and let me just say... what a mess that world is. It would seem that manufacturers are free to list whatever noise level they decide in fan specifications, and they almost never state how the fan was hooked up/powered in order to achieve those noise levels, so the search involved a lot of cross referencing to make the determination as to which fans to buy, and even after all of that I still bought the wrong fans the first time around (currently installed). Not to say there's anything wrong with them per se, they fit and function, they just happen to be too loud, too fast, and push too much air. Directly connected to the transformer output these were completely unacceptable, so the photos in posts above feature speed controllers set to the slowest setting. Even at the slowest setting the fans were still too loud to be acceptable, not to mention they emit a buzzing sound below a certain speed. I will note that I did also try several combinations of inline resistors, all of which failed to get everything to an acceptable level of performance. After several hours of additional research I arrived at the conclusion that it would be either highly unlikely, or prohibitively expensive, for me to find an acceptable (read: silent) solution that involved an AC fan and decided that the best route to go would be to retrofit the units such that I could use ultra-quiet 12VDC computer fans. This made the search considerably easier as I already knew where I would find the answer: Noctua. (when in doubt, just go for Noctua, in my opinion, high quality engineering and manufacturing, good reliability)
I went ahead and acquired two of their absolute quietest fans, which also happen to be two of their least expensive 120mm fan offerings. These super powered bad boys top out at a blistering 700 rpm, even slower with the noise reduction resistors I bought to accompany them, and while they don't move a huge amount of air and aren't ideal for high impedance situations (e.g. intricate heat sinks) they should be absolutely perfect for the Ampzilla. In testing them out, they're incredibly quiet, but I won't know exactly how quiet until I decide how to power them, as my bench PS is considerably louder (although brief tests with an old 12vdc adapter have shown that they are effectively silent running).
So great, I have nearly silent fans, but that still leaves me with the problem of powering them... before the suggestions come in, here are a few commonly discussed options I have ruled out:
- use a wall wart and power the fan externally (no no no no no, not in a million years, I will never do that... that "poster child for cutting corners", IMO it's lazy beyond belief and is just asking for trouble in the form of forgetting to plug in the fan, if you couldn't tell, I feel strongly about this)
- same as above, but hard wiring the wall wart inside the chassis (yes? no no no no no, among many other reasons, including wrong tool for the job, I need two identical PSs, one for each unit, meaning that these wouldn't be coming out of my large box of orphaned wall warts, meaning I will be buying new whatever solution I arrive at, meaning that if I am spending money on new parts I am at least going to buy the correct parts for the job)
- tapping the driver boards (just no, while this would likely work, and probably wouldn't noticeably affect anything, quite simply it is not a good practice)
- going the "purist" route and adding a mains --> 12vdc linear power supply (while I would jump at this option otherwise, as it is likely one of the best routes to go, what can I say, it's hard to justify the exorbitant cost of new linear PSUs, and that's coming from a guy who spent ~$300 on connectors, the ROI is simply too low)
Below you will find the shortlist of solutions I am currently examining:
- DC-DC converter powered at the positive filter cap
- cost is still somewhat of an issue, as is packaging/size of converters, possibly limiting options based on what I can squeeze in the chassis
- small, low power, correctly spec'd switching mains-->12vdc power supply (leaning in this direction)
- They're tiny, specified for just this sort of an application, and quite inexpensive
I know that some of you might not agree with this, but I will likely be going the route of the small, low power switching ac-dc converter. Yes, I have done my research and reading, and I am aware of the stigmas of having a switching PSU anywhere near analog gear. While I am an engineer, and I use my engineer knowledge as often as possible in projects, I claim no expertise when it comes to noise that would potentially be created by using a switching converter, however I am not going in blind here and have done some studying in making this determination... Yes, it appears to be undeniable that switching PSUs can create noise, and almost certainly will create noise to a degree, however based on my best, informed judgment, so long as I use a properly spec'd converter (mind you, the fan only draws a max of 0.6W 0.05A), and locate it as far away from low level signals and behind as much metal as possible in the chassis, the noise created should be negligible at worst.
With that said, as I mentioned, I do not have expertise in this area, so there are possibly factors that I have not yet considered, and I am interested in learning what the community has to say about this, so please share your thoughts if you have them!
