petes'picks
I tried to copy this video at the 2:10 time stamp to show the volume pot on the end. The first two pots on the shaft are open at the top but the rear two you will need to put the straw in that little rectangle endentation and give it a squirt. It appears to be located under the gyro tuning wheel and you may be able to get at them from the side once cover is off. At the 4:05 time stamp there is a closeup of what I believe is the volume pot.
I have some extra spray straws and use various methods to bend them to get to hard to reach places, sometimes heating them then bending and holding in that position until cooled works and other times I will bend them and use electrical tape to hold them in the position I need until done squirting.
