This has potential, given the experience with the Eico ST70,
Split, there is the opportunity of running the 16 ohm tap as an 8 ohm tap per channel (i.,e, split the transformers, but continue to use the tap for 8 ohms as 8 ohms, instead of scaling to 16 ohms). That would reduce the effective primary impedance to 2375 ohms- which could be good for PPP EL34s, PPP6550/KT88s, or even PPP 6L6GCs in Class A.
In fact, here's a 6L6GC alignment that would be pretty close:
Push Pull Class AB1 Amplifier
Source ........................................ Sylvania - 1959
Plate Voltage ................................. 330 V
Grid No. 2 Voltage ............................ 330 V
Grid No. 1 Voltage ............................ -24 V
Peak Grid No. 1 Voltage........................ 48 V
Plate Current (Zero Signal) ................... 122 mA
Plate Current (Maximum Signal) ................ 184 mA
Grid No. 2 Current (Zero Signal) .............. 5 mA
Grid No. 2 Current (Maximum Signal) ........... 11 mA
Load Resistance ............................... 3.8K Ω
Power Output (approx) ......................... 31.5 W
That's from one pair- two pairs, with slightly higher OPT impedance (effectively 4.75K per pair) and slightly lower B+ (see below) , should still be able to produce 50 watts easy...
If either EL34s or 6L6s were used, the reduced total heater current draw would allow a second driver/inverter tube to be added, for each channel. That would allow the use of either Williamson or Mullard front end designs...
BTW: I'm assuming the MO200 has the same type of voltage-doubler power supply as the MO60? If so, I wonder if it might be good to UN-double it- just make a MASSIVE current supply, at around maybe 310v or so? The resultant amp would wind up probably around 50w/ch or so- but it'd be the stoutest 50 watts imaginable, probably...
Regards,
Gordon.
OK, so this thread may not die just yet. After some back and forth with Rpampt, I sensed he wasn't ready to roll over on these yet, so I suggested we go forward and split the channels, and make this sucker be the best it can be with the transformers its got -- which is the agreement at hand. Afterall, if we start improving it to the quality of the Dynacos, then he basically just ends up with more Dynacos, which is really silly because he already has those. So, we'll go after these things as they are, to make them the best of what they are -- but with a re-purpose in mind for home stereo use -- and, knowing what we're starting from to begin with.
Stay tuned!
Dave
