The board has what I thought were clear instructions printed on it for wiring up the power and mute switches.I soldered a wire from j55 to the center pole of the switch and another wire from mute to the right-hand pole. View attachment 3647453
I see it now. ThanksThe board has what I thought were clear instructions printed on it for wiring up the power and mute switches.
Have you attempted to follow them? If so, what was confusing about the instructions? If not- why not?
Its quieter than v3.2 also. I’ll send you one of those to compare you wish.
Yes, you can add an external resistor in parallel with the 100k input to produce the desired load. Just don't do anything internal to the circuit after the input coupling cap. That would be bad as it will affect the settling/range of the input buffer bias loop with potentially catastrophic consequences.@mkane generously loaned me his V4 so I could hear it in my system. My comparison is with my dual opamp versions of the V2 MM and MC. I used my Dynavector TKR MC cart with V4 MC (60Ω loading) and V4 MM combined with Intact Audio's 1:20CU SUTs (25Ω loading at SUT) and then with my Nagaoka MP-500 MI with the V4 MM at both 47kΩ and 100kΩ loading. I don't do the eloquent audiophile speak well and even though audio memory is notoriously short I don't have any doubt that the V4 sounds better in my system than the V2 MM and MC. Regardless of the cartridge or whether the V4 was in MM, MC or MC/SUT the sound via the V4 was clearer than the V2. "A veil was lifted off my vinyl playback" in audiophile jargon I suppose. I am certainly aware that volume can influence the impression of sound quality but I used a SPL meter to get the volume as close as possible to my normal listening level plus at lower volumes I had the same impression: the V4 delivers excellent clarity.
The V4 was in a chain of gear (listed in my signature below) and with the V4 my system was really quiet. I had to get my ear a couple of inches away from my speaker's mid-range to hear any hiss/noise. In between songs or the lead-in grooves the background was quiet too. However, I played a couple of records that apparently need to be run through the US cleaner as I could more easily hear the random clicks and pops. Apparently, clarity does not apply to just the music but whatever the stylus encounters.
I like the range of loadings provided by the six resistors on the DIP switch and the fixed 100kΩ. I have @wyn palmer 's spreadsheet to calculate the loading if other resistor values are used and I may change the values since the Nagaoka MP-500 sounds really good at about 57kΩ. I need to look at the schematic to see if I could add a RCA jack that attaches to the PCB that would allow custom resistor values for cartridges (taking into account the 100kΩ is always there) that need odd loading.
I hope to be upgrading to the V4 in the near future.
The value of the resistance in any of the load positions is largely irrelevant, and the loops are stable even with all the Rs open or closed. The MM setting is more sensitive as the closed loop gain is lower, but I don't think that any of the values you propose in position 8 will have any noticeable consequence.Thanks Wyn. Good to know I can keep the six load resistors and add a load jack position to the 100kΩ. Also, I modified your loading spreadsheet by zeroing the sixth resistor position (Pin 8) and found that 5 positions also provided an excellent variety of typical MC loads. I could attach the load jack to Pin 8 to make sure it is in correct spot within the circuit. The external load jack/plug will allow loads for some MM/MI carts like my Grado (10kΩ), some Shures (65kΩ) and a Nagaoka I own that is best at about 60kΩ.
Just to be sure: 1) If I leave the Pin8 position without a resistor will it adversely affect the circuit? 2) If I fill Pin 8 with a resistor from a load plug and leave all other Pins OFF will that adversely affect the circuit? Thanks!
Thanks! Below is my attempt to figure out the load plug value for a variety of possible loads with the 100kΩ resistor in the circuit. Below about 500Ω the plug value is essentially equal to the target load but those values start to diverge around 500Ω to maybe 3000Ω. If the DIP switch is hard to reach for some reason or someone wants to change loads frequently then using just the load plug might be handy. Hopefully this chart is correct.The value of the resistance in any of the load positions is largely irrelevant, and the loops are stable even with all the Rs open or closed. The MM setting is more sensitive as the closed loop gain is lower, but I don't think that any of the values you propose in position 8 will have any noticeable consequence.
It looks fine to me, having looked at a few results.Thanks! Below is my attempt to figure out the load plug value for a variety of possible loads with the 100kΩ resistor in the circuit. Below about 500Ω the plug value is essentially equal to the target load but those values start to diverge around 500Ω to maybe 3000Ω. If the DIP switch is hard to reach for some reason or someone wants to change loads frequently then using just the load plug might be handy. Hopefully this chart is correct.
