wyn palmer
Addicted Member
Sorry about the bad FET. Hopefully you have a spare.
I've always wrestled with switches on those 10mm front plates. I've found only two choices, because the bushing on the switches are not long enough to fit through he plate. One option is to thread the hole and screw the switches directly into the plate. I've done this several times and it's not difficult. You can find the size/thread pitch on the data sheet (there are several in use). Then purchase the proper tap(s). Amazon is OK because you don't need high quality tap(s). The other option is to back-mill the plate so the bushing goes through the remainder. This is difficult to do unless you have a milling machine but easily done if ordering from Modushop or Front Panel Express.Hello, I've moved a bit. The Transimpendence MC Phono preamp V1 will be finished, but it will probably be tedious to properly finish everything mechanically at the level I chose. Everything fits well in the chosen box. Please do you have any ideas for switches that would be suitable for this. I have ordinary ones that don't really fit. Photo below. Greetings for now, I'm going to continue.
Thank you hirscwi!
Pavel
Thanks for the kind words!I couldn't have done it without him. He's been an excellent collaborator.
Thank you. To my knowledge only you, Bill Hirsch, and I have actually heard this beast working. I'm glad that it seems to be as advertised.Once again I would like to thank wyn palmer and hirscwi. It plays very well and cleanly in the entire frequency range, very balanced, huge image to the sides and depth. It is very quiet. Transimpedance works exactly. You guys are doing an incredible job here for people. Thank you very much, I appreciate it. Sorry for the bad English, I use Google translator.
Pavel![]()
No.2R2 Ohm left at the input. In this state I received the schematic so I did it that way. I'm not one to change the design. Is there anything else I should know about this MC preamplifier. Thanks.
Pavel
Thank you Pavel. The design seems to have gone dormant. Sota have had it and have listened to it and are interested in a production worthy version having conducted listening tests against a number of extremely expensive alternatives, which went quite well, but Bill Hirsch and I have minimal interest in doing the work for them and they seem happy to sell the inferior Pyxi (now at $450) and would reserve the new design for a high-end unit.Hello, after listening for a while, I have to take my hat off to the gentlemen who created this masterpiece. It sounds incredible! Thank you,
Pavel
