The Official Kenwood KD 500/550 and 600/650 Owner's Thread
It was 1/8". I found some 3/4" red oak plywood at our building that im going to use instead. I have a lot of practice on how not to cut circles now haha. So this is one should turn out better.
Ive been resurrecting a KD-3055 with the “marblesque” plinth.
Mine has a few chips - does anyone have any recommendations as to what to use to fill/repair chips?
Finally got my KD-500 completed and up and running. Splurged on a Morrow PH6 phono cable that was on BT. Between the table, the New Jelco arm and that cable, this thing has left my 1200 in the dust.
i took that as aaaandd... how's it sounding?
looks killer!
My bad, I didn’t see a “?” At the end, usually the “...” is like saying “OK”.
Sounds great, mounted an AT13Ae to the arm while I was setting it up. I’ve ran the table for a number of years now, I recently put it away for another table I was playing with. I pulled the arm off a few months back to take some measurements of the arm board, and never put it back on. I need to get the new arm boards in to mount a few otter arms I have I want to try.
I honestly don't know if I would make another armboard without a drill press for the hole saw, it is sketchy and rather dangerous, especially if the teeth catch the wood. And it is really hard to drill it straight even though it is supposed to somewhat self straighten. I used a 4 1/2" hole saw, which makes a little over 4 1/4" diameter armboard. I made that armboard out of red oak veneered plywood.
I made armboards for my KD-600 by cutting them down to size and then using one of those spindle sanding drums to get them right to fit the cutout. I need to drill the holes to mount them but they are marked and ready for the drill press but I have to go somewhere for that. Soon enough. If I had a KD-500 I'd make a pile of boards for that machine, too. These will be in use soon enough.
Currently the Magnepan arm is mounted to an Oiled Walnut armboard on this table. The above are unfinished.
If you have a router it can be used to make nice round holes, the center cutout of which will also be nice and round.
The SME arm does not use a round center hole to mount the arm.
The position of the hole may not be in the center when put where the template indicates where it should go.
Apparently you've never used a router, it will cut any shape you want, even letters lol.
