Nah just letting folks know that round holes in the center ain't the answer.
You misunderstood my post. I was referring to cutting a round hole, the center cutout "would be the arm board", never discussed the arm cutout In the new armboard.
If attempting to make nice round armboards use a router to cut out a piece of wood, in other words, cut a hole, the center that it cuts out will make a nice round arm board.
You can also use this method to make any shape arm board you need. Can also put sanding discs in a router to finish the edge if desired, routers are very versatile tools.
I've even used one to make speaker cutouts, then radius the edge of the hole with the driver rear mounted. If building speaker cabinets etc in your garage without all the stuff you would like in a wood working shop a router is a must.
