.3"=1/3"Did you mess with the 4 screws on the underside that atach to the springs and changes this distance? and in english what's .3"
Dan - no I have not touched the springs (I know better than that). All I did was re-do the mass loading in the tonearm well to get everything level and balanced.Did you mess with the 4 screws on the underside that atach to the springs and changes this distance? and in english what's .3"
.3"=1/3"
That hight is good and the platter should not be close enough to rub the top of the motor. The table should be able to bounce down to the feet without touching the motor. I have a feeling you only think it's rubbing there. Pull the motor/switch cover and run the table. I have a feeling the motor puly is rubbing on the switch cover.Subchassis hangs down between 1/4 and 3/8 inch from bottom of plinth. As far as I can tell it is setup perfectly
I'm stumped.
That is your bearing, be careful with it and it should be locked down while working on the table. When you do pull the platter, take a bunch of photos so I can see the inside, platter and all related parts.I also have the square (vs round) platter base,
Its the Composite (3 layers of acrylic with aluminum) board, not the Cosmos (which adds lead). Donna re-classed it as b-stock as there is a minor blemish on the top of the board - think I paid $228 plus shipping (I got a few other things too) and they drilled it for the Audiomods. I can't see the blemish unless I look for it, they buffed most of it out. It seems a lot thicker than the wood board my Sumiko is mounted to now, it definitely weighs a lot more. Now I just need the arm, my MC cartridge is too heavy for the Sumiko so I have a Grado mounted on it for the time being (which sounds great).How much was the armbord?
I have the aluminum one now and was think of changing it.
I modded my RD40 back in the 80's and it sounded great.I think your right, I just picked up Mr Pigs Marcmorinfied AR XA and it's excellent in every way. I may think about letting go of my Ariston rd 40 that's fully customized as well and source a Sota.
$30k Aussie mate sorry. About $23K New Jersey money. RIP RichiePan. (Tattooist and Harley Pan rider from NJ.)If I had 30K I would buy a Cosmos SME5 and spend the rest on vinyl
