Frank Sol
Lunatic Member
I recently purchased a periphery outer ring from TTweights -
Looks nice!
However, I had a question about using one on a 1200 with a KAB Fluid Damper attached. From the 2 pics I do not think it would work.
That looks really cool, but aren't you worried about all that extra weight taking its toll on the turntable?
No worries whatsoever. The Applied Fidelity upgraded bearing that I had installed can handle the extra load and the tt motor is up to the challenge with inertia as an added bonus.
Welcome aboard!New owner, checking in. SL1200MKII. Carry on![]()
Ok. Lets SEE it! welcome. don't just duck in and leave, hang out a while!
Looks like all the other stock tables with a bit of dust and the wording half worn off the power switch.I've been reading a lot and trying to actually do my job at the same time. No photos yet. Just ordered a JICO Shibata stylus for the 680EL that is installed. I need to trace out a grounding issue, I get hum with the ground wire grounded, a bit less with it not. I aslo need to replace the pop up lamp and dust cover. All in all, not a bad buy for $150.
Thanks. I'll give it a look.I had a similar hum problem. It was actually corrosion and oxidation on the headshell contacts (the ones on the back where it enters the arm). I cleaned these with steel wool and a pencil eraser. Did the same on the contacts on the arm side. No more hum.
Check out Viperfrank on you tube. He has a great tutorial on upgrading the bulb to an LED. MUCH longer lasting and you could even pick a colored LED.
I did this to a MK2 I just finished restoring.
Wow, very very nice!
What's that to the left of the 1200? I see a modded AR-XA behind it, I think.
To the left is a LPB S7 (same as QRK 12c) with a sedco arm. Currently my favorite. The AR was nice and very good also![]()
OneMixDJ,
Welcome to AudioKarma!
Great seeing photos of your gear.![]()
I don't actually have a SL-1200 but a SL1400. Anyone know how different it is?
I like to change the arm eventually to maybe a Rega RB300 or RB301.
