Mister Pig
Pigamus Maximus
With the Amadeus and likely others (I haven't looked closely) the set up is not difficult but there are some parameters that can leave one guessing. That's another way of saying there are adjustments that aren't black and white.
The bridle filament length can be adjusted to suit a particular cartridge. The fluid cup is adjusted to immerse the golf ball or equivalent fixture to a preferred depth. The tonearm pillar and bridle filament and fluid cup all have undefined optimal settings. VTA and ball/fluid depth are inextricably related for a given amount of fluid. The azimuth collar needs to be set. They can leave a user who prefers exact, prescribed measurements in doubt or maybe just uncomfortable. So hard to set up may be defined differently depending on one's idea of pursuing a specific target. To some these available adjustments would be a source of anxiety, while others would appreciate the flexibility.
The Well Tempered Reference arm is a previous generation, but its very friendly to set up in most respects. The knob on top of the gantry makes the azimuth adjustment a breeze, and you can do it while its playing on a record. If careful, you can even adjust the silicone cup while the turntable is playing and thereby changing the damping and effective mass of the arm. To be honest, I can't see any significant difference in using a golf ball in place of the paddle assembly, as it all has to do with the depth of silicone and how much damping it applies to the golf ball or paddle. In the WTR you can adjust the cup and get the paddle deeper thereby applying more damping, while in the golf ball you add more liquid and possibly increase the filament length to get the ball deeper into the silicone and accomplishing the same thing. But hey I am just a simple pig, so maybe there is a deeper understanding that I am not aware of.
The only adjustment that is truly difficult is overhang. When changing cartridges you have to loosen the bolt that holds the arm base assembly, as you can rotate it and change spindle to pivot length. The head shell only has bolt holes like a SME arm, and therefore you cannot move the cartridge within the headshell. VTA is set by a thumbscrew on the pillar of the table. While there is a numbered scale on the side of the arm to use as a reference, making the adjustment is the old basic lift and lower the arm. I am tempted to get a plastic bike tire changing tool as they can be used as a lever under the base to make fine adjustments instead of trying to raise and lower with only hand movements. Also adjusting the counterweight becomes an acquired skill as the carbon fiber arm tube is a bit rough, so making those tenth of a gram adjustments a bit tedious.
Overall though a very nice arm, and I enjoy using it.
