No. Very different spindle stock. The prototype is much smaller. And lighter. Which brings me back to my question about the dry bearing. I know the set up we’re used to is wet but this one is dry. The plater and spindle are VERY light. I’m wondering if it needed lube. Was he experimenting there also?is the platter interchangeable with your classic? Would be interesting to hear what the differences are between the two.
I’ve been snooping around but as yet haven’t found him. Of course I registered with FB yesterday in order to look him up, so I’m terrible at navigating around it so far.Has anyone figured out what Bill Firebaugh's presence is on FB? I just sniffed around and did not find any Bill or William Firebaughs that seemed likely. And the Well Tempered Lab has a FB page, but that's not Bill (if I interpreted correctly the posts above).
So does this mean the recommended route to Bill is through WTL?
The reason I ask is that the foam layers in my plinth appear to be sublimating. If I scootch down to the level of the plinth and look at the front face of it, I can see light in between the layers of MDF. In former times that was not true. Also my three layers of MDF had drifted out of alignment with one another at one point (I may have mentioned this earlier in this thread, wasn;t anything I was particularly concerned about). A recent check with McMaster-Carr and other suppliers yields a number of 1/6" foam products — urethane, polyethylene, rubber, silicone — and I would like to ask Bill which material he feels would be best suited for the transfer/absorption of vibration. What I faintly remember from my days working with Transparent is that he had used 3M brand foam, which I'm pretty sure is urethane, and this raw material would make sense since that tends to break down over time and lose flexibility with exposure to sunlight, etc. In the case of the plinth, sunlight not an issue, but still. IN any event, nothing better than going to The Source to pose the question.
I am always amazed at some materials ability to "creep" with thermal expansion and contraction.
I would wager that @Barncats top section of plinth is experiencing some temperature differential that cycles causing the top section to creep over time. Especially if the foam layers in between use some sort of highly cross-linked polyurethane adhesive.
Of course the most obvious would be sunlight which could easily cause creep if it hits one side of the plinth 1st then moves across the plinth where the original warmed section is the 1st to cool. However, I can also picture a subtle air flow from a vent doing the same thing. Who knows. It doesn't have to be extreme given enough time.
I can't help thinking of the Sailing Stones, but of course that has been determined to be caused by micro ice sheets and wind. Still, seemingly inanimate objects can be moved by the most mysterious of forces.
If your using your cell phone to record and upload it’s the plus button at the bottom of your phone and it will give you the option to select the video you recorded on your phone , once it’s done uploading you go to your video and click on the share tab and select copy . Go back to AK and paste the video where you want.I was going to let you guys listen to a vid of the table doing it’s thing but YouTube has changed how to upload and I haven’t found it yet.
But
It’s playing away and putting out some killer bass. It’s really quite nice. I’m really amazed with it.
Looks and sounds greatOk let’s try this out. I chose this record as the first because it was 2 bucks.
Then I went on to Dire Straits to check separation. This vid is from the side but trust me it’s great.
This is my Marantz separates system. A 3250 pre fed by a BelariVP 130 with a Ruby tube. The amp is a 170 out to RSL Elans. It’s a casual little system.
Thanks to Audiofreak71 for the help.
I have a WTL Amadeus and the bearing well looks very similar. I think the spindle bearing calls for 5w-30 synthetic. 1/3 full so as when the spindle is in position it doesn't overflow. I seem to recall specifically a caution as to avoid over filling for that reason. Is your bearing well a sealed space?No. Very different spindle stock. The prototype is much smaller. And lighter. Which brings me back to my question about the dry bearing. I know the set up we’re used to is wet but this one is dry. The plater and spindle are VERY light. I’m wondering if it needed lube. Was he experimenting there also?
