the oldest component in your rig?
Unfortunately my oldest piece is a Westinghouse B&W tube TV, not really audio eh? Not sure which is older my Fisher RS-1080 or my Advent1's, maybe my Mach One's?
would have to be my Pioneer CS 51. Very nice PE 12 woofer in it.
i think its about a 4 inch or so woofer give or take a half inch
EDIT---its from 64
Here is the video of the gramophone I promised earlier.
http://www.youtube.com/watch?v=kJPbsJ8UN2E
Very nice. :yes:
I like the song as well. It reminds me of The Little Rascals. :thmbsp:
The oldest gear I own that functions are my 1937 & 1939 Tung-Sol Valves.
Best Regards,
Of all the different systems I have in the house now the oldest in use is a pair of EV Leytons which I believe date from the mid 60's.
Oldest? I would say if we are going by production dates- my 2 Quad IIs, my 3 Quad QC IIs, and my Fisher FM-50. If we are going by how long I have owned a piece it would be my Rotel RX-1603 which I have had for almost 20 years.
The oldest piece in my system is my Rotel RCD 1070 CD player circa 2002.
I have older stuff around that i hook up for fun every once-in-a-while.
I think the oldest of the lot is my Garrard AT-6 MKII record changer circa 1964 which is still running the original Pickering u-38 cartridge. (new stylus, of course)
I have turntables from the 60's, my father has an about 100 years old Edison Gramophone with over 100 cylinders (some can not be listened to anymore).
My fully recapped Trio WX-100 was marketed in 1963 and currently in daily use. Contrary to its nostalgic appearance, its 6BQ5/SE sounds fairly nice.
My oldest piece of still-working gear is a 1923 Stromberg-Carlson Neutrodyne radio, but that is stand-alone, and not part of the main system.
Most of my system dates at least from the 1970s, but I have several TTs and changers that get changed in (pun intended :D) sometimes: Thorens TD`124, Collaro 456, and as soon as I get it restored, a Garrard 4HF, all of them from the 1950s.
I'm planning to set up a separate mono system featuring one of these, and as soon as I get a matching stand-alone arm for the Garrard, I'll probably make that a dual-use TT, with one arm for mono 33s and another for 78s.
I think the main system will remain primarily 1970s-onward, as the best-sounding gear I've found dates from that time period. Earlier stuff can sound great, but not QUITE as good as the best of the later stuff. I like using earlier gear for playing earlier recordings sometimes, though, just for the nostalgia of it, plus sometimes contemporaneous gear makes the old recordings sound better (IMO), probably because the stuff was "tuned" using other same-era stuff. Ears haven't changed, even if gear has.
Oldest is a 1925 Vitrola, used during power cuts. Next would be a pair of Scott S-10 speakers used in the bedroom system about 1971.
wow very cool everyone!
Hi.
I noticed you mentioned you were 26.
I am thirty and, 90% of my audio gear (Home/Professional) is older than me.
If you are fascinated with vintage equipment, there is no time like the present to start exploring, learning and, experiencing audio products designed decades ago.
Best Regards,
