Toasted Almond
RIP 1952-2016
So how did that "stacking" work out for you?
If you almost burn down your trailer hooking up dozens of thrift store units at the same time-
You might be a redneck.
Jimmy
No, the current was too much. I reckon you were putting around 100amps through wire that was meant for much less.. the voltage was just too much for the old wiring to put up with, the living room wall was burning from the inside.
A lot of this story reeks of BS.
1. It would be difficult to find enough room to put 100 speakers into a trailer even a double wide.
2. It would be virtualy impossible to find enough electricial recepts to plug in 50 amps/receivers in a trailer and even if you used a dozen surge protectors the circiut breakers should have flipped long before a fire broke out.
3. Once a fire does break out in a trailer it spreads insanely fast, I truly doubt you would have time to put it out.
4. I doubt that other people would dontate their gear to this cause.
5. That even if it did happen why would you post it here is a mystery to me.
REGARDS JIM
