Hi All - So still trying to trouble shoot my SL-1100. As reminder, it was struck on the very front edge and now works only intermittently - but seemingly randomly. It powers on with no problem, but will only start when it seems to want to.
I have thoroughly inspected the micro-switches, solder connections, board, even opened up the drive and made sure nothing was loose/blocking the magnets. I have replaced the two SS-5 microswitches in the start/stop assembly and checked continuity all the way to the circuit board. I have checked continuity on the two microswitches in the power/speed selection switch. I'd love to replace them, but I cant find replacements. (Matsushita AM9715 and Matsushita AM78909) Both seem to be working fine.
I have checked continuity on all pins on the board and don't see any obvious solder cracks/damage.
I have enough electrical knowledge to check continuity with a multi-meter, but to actually check each individual component on the board, i'd need some guidance.
Bottom line, all seems in order but it still only starts intermittently. I can't figure any rhyme or reason to why it does sometimes and why it doesn't other times. There is NO physical change from the times it starts to the times it doesn't start (I.e. it isn't jostled, moved, etc. The conditions are constant.)
I'm looking for ANY advice anyone can give. Really frustrated. Ready to part the whole thing out if I can't fix it.
Help!
View attachment 2438787View attachment 2438788View attachment 2438789View attachment 2438790View attachment 2438791
