After reading countless threads, and in anticipation of my two MC501s which should be coming soon, I'm pretty much convinced that I should run a few dedicated circuits to the room where my system will be in (at least 3 15A, one for each amp and then the third for the MDA1000/TV/anything else).
I had an electrician come out to give an estimate, and he seemed to be pretty skeptical about ANY sonic benefits of running dedicated circuits for the equipment (keep in mind, the room currently has ONE circuit which also has a bunch of computer equipment plugged into it), which got me to thinking, what exactly does one need to specify with an electrician when running dedicated circuits for audio gear in order to maximize sound quality?
I already ordered some well-reviewed cryo treated hospital grade outlets from A-gon, but beyond that, is whatever the electrician does going to provide the full benefit of running the dedicated circuits, or do I need to specifically ask for certain things to be done? Assume an older electrical panel that's located indoors on a somewhat middle aged home (built in the 70s). I just want to make sure that since I am going to be tearing up the walls a bit that I'm going to get the best possible performance out of the job (without going to extremes of course, he quoted me around $500 for the 3 new dedicated circuits and I'd like to keep it as far under $1,000 as possible). Thanks for the feedback and advice!
