KA907nKA9900
The best thing you can do regarding the cables is to replace them with new, a bit of work but regarding.
The D1 is a diode that goes attached to the heat sink, reference STV-4H discontinued:
"The only real substitute for a STV-4H diode is four 1N4004 diodes in series (or four UF4004 diodes)." Says EcoWars here:
https://audiokarma.org/forums/index...ubstitution-on-a-sx-838.741918/#post-10055673
Here is how he made them to be able to install them the same way as originals:
https://audiokarma.org/forums/index...v-3h-and-4h-diodes.279530/page-2#post-3446343
You will have to check also the drivers Q1 and Q2, from your pictures doesn't look like the originals. They can be replaced with the Sanyo 2SA1011 2SC2344 currently available in Bdent:
https://www.bdent.com/2sc2344-sanyo-audio-power-transistor.html
https://www.bdent.com/2sa1011-sanyo-audio-power-transistor.html
I just helped a friend in my city to restore his, amp also a KA-907 and we used these transistors. Worked pretty well. For my amplifier I used Toshiba 2SC4793 & 2SA1837, but they were a gift from our fellow member @Bratwurst7s as they are not available.
Going backwards in the amp, in the pre-driver section X00-2010-10 (B), also check Q15 to Q20, there is a big chance some of them are bad. You can replace them with Sanken 2SA1859/1859A & 2SC4883/4883A (you can find them in Digikey). This also done in my friend amp, without problems.
Good look in your restoration @KA907nKA9900, to restore mine toke me 4 months and also importing all the parts, so be patience
Cheers!
Re-reading this and responding a second time.
Lots of gems in this post.
Thanks for being so detailed.
I wish I had come here as soon as my amplifier died. This forum kept showing up in my searches back then, but my thought then was raising the money to ship 25kg to @EchoWars and back....that is quite a sum...and so I never got around to do this
In the meantime I learnt a lot about electronics to be comfortable enough to play with it and attempt this restoration at much less cost to me and with the great satisfaction of doing it myself
But better late than never.
Thanks again.
I am budgeting 4 to 6 months to get everything back in order
