was at the beach for the weekend but this is late, however consider something...View attachment 1292094
The primary electrical system is the electrical system on the utility side of the transformer. ... When electrical current cannot flow through a neutral conductor, due to some type of damage or defect in the circuit, more current will use a path through the earth to return to the power supply.
The earth is not the normal neutral in the grid.
recall the question asked day 1 of class, the true or false (see previous post)
At your service entrance the neutral of the 220 is derived from the center tap of your transformer, and the 1.5kv (or most likely more) is the result of many step down transformers from the actual power plant.
AS power leaves the plant, each circuit is stepped in voltage based on the load capacity of each branch and the voltage reduced. we all know kirchoffs and ohms laws and there are fancy charts to show us conductor sizes for various currents. but there is this other law called the catenary law that lets us derive the forces on a hanging wire and it tells us when the forces generated by the weight of the wire overcome its breaking point. To carry the power or a village at 220v, the wire might 6 inches thick and it will break, so someone, somewhere, sometime ago did the math and figured if they up the voltage - drastically - then less current has to flow and hence a lighter (smaller) wire may be used.
The point of the history/physics lesson is, many many step downs occur, from the power plant to your house and at each point of step down, neutral is redefined. since wire has resistance, you end up with a floating neutral to even a delta power concept sooooo, what do they do...
they ground to earth every single neutral connection, outside of a building, no matter how many or where they occur.
as I said before, on the pole, the top contains the hot/live wire. the lower wire contains the neutral which is ALSO the ground and this is reinforced every so many feet along the path. hundreds of times? thousands of times?
If current is indeed following EVERY path to ground, how many connections start to make a real difference?
I assure you, if penelec lets you do testing you will find that at the source connections of every step down, the current going 'out' on the hot wire far exceeds the current coming 'back' on the neutral wire, the balance going thru worms and stuff. It has to, It has no choice.
ETA: corrosion and degradation of the wires...all of them, occur at a fairly static rate. There can and does come a point where the overhead wires fail as the current approaches the limit of the wire left but does not exceed the fusing. unless something hits something and its a mechanical failure, its always (99.9%) the hot side that drops...
