peja11
................. Yep neutral and ground are one and the same for 120. Each leg of the incoming 240 referenced to ground is 120. Dont need to get out a slide rule to figure that out!.............
I agree with what you are saying in context but the neutral and ground are two different animals. A neutral/white wire is a grounded conductor required for return path to ground to complete a circuit. A ground/green wire is a grounding conductor which provides an alternate path to ground for "stray" voltage from a circuit. Both are electrically connected to the same place in a panel. In an ideal world a grounding conductor/green wire would never have current on it.
I know the above is mostly electrical semantics. You would be amazed over the years how many circuits I've run across that had the green as a neutral or green and neutral in parallel with current on both. Yikes. Gotta love the DIY'ers
