When you can instantly switch from corrected phase to the uncorrected phase response that a speaker like the La Scala or Klipschorn presents, yes it’s like night and day; once you’ve heard it, you can’t unhear it. That said, most Klipsch-heads and horn aficionados have no idea how bad their speakers truly are. They’re truly awful.
It used to be that hi-fi enthusiasts would try new things and techniques, then report subjectively and others would try out those new things and then add their opinions...because no one could afford acoustic measurement gear back then.
Over time, the available fidelity that hi-fi enthusiasts* could achieve in their listening rooms began to improve to the point that the limitations of their listening room acoustics themselves started to become a real limiting factor**. About this same time, shareware room acoustic measurement apps and inexpensive measurement microphones appeared, and DSP crossovers improved in quality and affordability to be true game-changers. Now real hi-fi measurement capabilities can now be easily accomplished, and for next to nothing. In my view, it is foolish to try to pass up these sort of capabilities. If someone is initially intimidated by their inexperience and won't do anything to educate themselves to use these game-changing capabilities, their response is eventually extremely self-destructive.
Having said that, I can say that I've personally witnessed full rooms of people (supposed hi-fi enthusiasts) that
couldn't consistently hear the difference in largely blind tests. I don't consider my hearing abilities to be "golden ear" by any means...but I also find that I'm not "tone deaf" either to these sort of large differences in hi-fi reproduction capability. I was astonished to the point of disbelief. It took a
long time to muster the presence of mind to mention this experience to anyone else. It shook my confidence in believing virtually any "audiophile" subjective hearing abilities. This includes (especially) audio magazine or reviewers of any sort.
I now can't help but question others' hearing abilities: and many times, they tend to present themselves like someone sitting on a busy street corner with a sign that says "I've got a hearing disability" but then take umbrage to anyone coming up referring to the subject of their sign.
What I find that begins to occur is that people stop making any sort of comments at all to that person sitting on the corner holding that sign--and actually start avoiding walking by that street corner altogether.
Chris
* Here defined as those enthusiasts that use
both in-room measurements and subjective listening to assess hi-fi performance...and
not those that cannot, will not, or haven't yet taken and interpreted in-room acoustic measurements (like REW provides) to help inform them of verifiable progress toward actual hi-fi.
** If you're unsure of room acoustic problems that are being referred to above, that list includes problems like:
- canted ceilings due to roof-top contours (that usually end up requiring almost total absorption on all of the canted ceiling/side-wall surfaces to control early reflections, and this isn't usually enough to make the room sound "good")
- acoustic reflections between the loudspeakers because of "stuff" between the loudspeakers (which compromise phantom center imaging severely and also mask phase flattening performance of loudspeakers)
- pulling the loudspeakers out away from the room's boundaries because the owners won't put down effective absorption to control early midrange reflections on the front and side walls (and sometimes the ceiling, too if it is low enough)--which all compromise phantom center imaging and soundstaging, and add significant bass modulation distortion artifacts to realistic listening levels.
- things like coffee tables and other chairs between your listening position(s) and the loudspeakers, and acoustically reflective high-back listening chairs that reflect sound near the listener's ears, etc.
- (If you're the type of person that never shows a picture of their listening room with loudspeakers and listening positions--ostensibly because you're afraid people will see that you've got some real issues--you're likely someone that's in denial as to the source of "not being able to hear the differences" of things like subtle-but-strong performance enhancements in flattened loudspeaker phase response.)
