I'm sure you will have a positive experience with this combination of driver/horn. The midrange opens up and the micro-detail and transient response are amazing.Thanks. My Cornwall 1’s with new ZXPC 18x10’s and PRV D2200’s will be done shortly. Once evaluated, I will post comments on my impressions.
Fired them up tonight. Did someone mention midrange? It’s here in full force. From my limited time listening, they sound really good. Lots of midrange clarity and it seems like less boomy bass which is good. I’ll keep listening over the next few weeks but my initial impression is positive but my gut feel is the crossover needs tweaking to smooth things out a bit. But even as is they are very enjoyable. I’ve never heard such attack from Hans Theesink’s guitar. I’ll probably come looking for crossover advice in the near future. Right now just using the Type B with the added .25mH choke.Thanks. My Cornwall 1’s with new ZXPC 18x10’s and PRV D2200’s will be done shortly. Once evaluated, I will post comments on my impressions.
Welcome to the world of bigger horns and drivers. I joined 16 years ago after Jubefest 2007's introduction into the PRO world of speakers. Never went back except for Super Heresy mods for Surround Speakers (inspired by Klipsch Pro versions) with DaveTN's superior tweeters.I’ve never heard such attack from Hans Theesink’s guitar.
It's a Tractrix Style horn, totally different from PWK's K400. I'll let you know when I measure it.What is the dispersion like with the PRV and ZXPC? Since this appears to be a "shorter throw" horn than the K400 , I would assume it is better but by how much?
I did not measure dispersion. Most, if not all, of my listening is on axis. In addition, I'm more concerned with the "sound" of the horn which the dispersion will have an effect on, but the dispersion won't define its main sound characteristic.What is the dispersion like with the PRV and ZXPC? Since this appears to be a "shorter throw" horn than the K400 , I would assume it is better but by how much?
I gave up measuring off axis. Used to do multiples but now only do on axis and 30 degrees. Good enough to know the curves.I did not measure dispersion. Most, if not all, of my listening is on axis. In addition, I'm more concerned with the "sound" of the horn which the dispersion will have an effect on, but the dispersion won't define its main sound characteristic.
I have not mastered measuring dispersion yet, but maybe one day.
It's definitely the one different thing between it and the K55......the PRV keeps on going to 9KHz and needs to be shunted and allow more sound from the tweeter.
Any follow-up comments after listening for a month?Fired them up tonight. Did someone mention midrange? It’s here in full force. From my limited time listening, they sound really good. Lots of midrange clarity and it seems like less boomy bass which is good. I’ll keep listening over the next few weeks but my initial impression is positive but my gut feel is the crossover needs tweaking to smooth things out a bit. But even as is they are very enjoyable. I’ve never heard such attack from Hans Theesink’s guitar. I’ll probably come looking for crossover advice in the near future. Right now just using the Type B with the added .25mH choke.
Made them with basic plywood in efforts to match the decorators. The sub in the photo is not used.
IMO, adding the "swamping resistor" to a Heritage network allows you to easily modify and make incremental changes more easily than just modifying a normal Heritage network.Hmmm......thats one route I have yet to go with the crossover in terms of using the swamping resistor on the autoformer. I may try a version of the B-2 network except have 6.8uf as the first cap before the autoformer. At the very least to get a gauge. But that also still runs the PRV all the way out and unlike the K55 which drops off at 6kHz the PRV still has plenty of output out to 9kHz. Just need to figure out the inductor value for the mid (I've got both .5mH and .245mH on hand).....The B-2 uses a .245 in parallel to the tweeter as a 2nd order.....and I've seen both values used in series from the autoformer with the mid (K55 and/or PRV). I'm using a B&C 120 tweeer atm instead of a DE10....either way I'm more concerned with stopping the output of the mid above cutoff as opposed to sharpening the skirt on the tweeter as they can go lower than the K77.
Some material sounds fantastic, but most a bit too forward. Funny timing for you asking as I was just about to make a change on the Type B. My 1st step was going to be simply go to tap 2 instead of tap 3 on the mid and listen for a while. After that I was going to insert my B-2 networks with the .25 mH coil on 3 or 2 depending on what I hear on the Type B on the tap 2. I know this is not very scientific and maybe throwing things out of balance but just want to experience minor changes first. After this I am leaning towards a universal variant with the swamping transistor. I am also wondering if mounting the larger mid horn on top of the cabinet and above the SMAHL is contributing to the forwardness. I appreciate any comments as I am only relying on what I hear and my changes are not based on calculations or measurements. I’m sure that upsets a few here but I don’t have the technical knowledge or equipment. Thanks.Any follow-up comments after listening for a month?
