Your 202 is rated for a nominal input voltage of 105VAC to 120VAC. Today's voltages vary day to day, and hour to hour. Agree with Gadget73. As long as your heater voltages are no more than 6.5 (or 12.8v for 12v tubes) you are ok. Lower is always better TO A POINT with input voltage!
No matter what the input voltage the heaters have to remain about 6.3v or 12.6v. I habitually run my TA-600 (1960 build) straight into the wall. The heaters vary from 6.0 to 6.3. Wall voltage varies from 122v to 127V depending on loads, time of day, season, etc. About the only gear i have on a 6.3v Bucking transformer is the 800-C inside of the EXECUTIVE VIII cabinet. The heaters run as above but it runs a little cooler than it normally would but it's still hotter than my 800-C that sits out in the open.
Take some readings at different times of the day over a week. Say 4 times a day. Average out the voltage. 4 times a day would be when you wake up , lunch time, dinner, and right before bed. Use your DVM set on 200V AC! NOT DC.
