JLange2010
Well-Known Member
I found this TIP - Place a small Class X1 rated capacitor (around 0.1 uF /275 volts is fine) across the switch contacts. This will help protect the contacts from arcing and also stop them from making a noise when the switch is operated. This is optional but recommended. here is the whole article http://www.decdun.me.uk/gainclone_psu.html
Can someone clarify this tip for me, as I don't really even understand what a capacitor does - you are saying that the capacitor should be installed with one lead on the power supply side of the switch, and one on the power output side? So that, if it were just a straight wire instead of a capacitor, it would effectively bypass the switch? I read the referenced article, but it didn't explain this tip in any detail.
