wyn palmer
Addicted Member
It's highly unlikely that there will be problems simply because a transistor is replaced with another transistor with a 2x FT, all other aspects being equal, in an audio application.Hello Again,
Continuing the question of FT, do you think it could hurt to replace Rotel RA-01 15Mhz output transistors (2SB817/2SD1047) with 30MHz toshiba or Fairchild 2SA1943/2SC5200 ?
FT simply means that the device maintains its beta/hfe/current gain as greater than unity up to
that "transition frequency"- at FT IC=IB.
In general a higher FT is a good thing and it's highly unlikely that a 2xFT will be problematic.
For a technical analysis see:
https://ocw.mit.edu/courses/electri...vices-spring-2007/lecture-notes/lecture37.pdf
Basically, FT is a function of the base width of the transistor.
Usually the current gain of the output devices is NOT a significant contributor to the gain, stability, or loop bandwidth of an amplifier. Amps with feedback usually behave like inductors at frequencies beyond where the open loop gain falls due to the increase in output impedance caused by the reduction in the amount of negative feedback, and this will not be affected by the increase in the FT of the output devices.
At frequencies above FT/beta (about FT/100) the output devices themselves start to look like they have inductive output impedances, but this rarely is problematic.
