Transistor Substitutions
I believe the KSC 1815 is more durable and higher spec... compared to the KSC1845...at least in accord to the posts here...you may consider verifying spec.
I went with the 1815 also based on other posts. Thanks for the reply.
BTW... Go Lions! (And the Wolverines!!!) ;)
Looking for a substitute RN2209, anyone got anything that will work? Thanks for any and all help in advance.
The surface mount version(RN2109) is available from Mouser. You can probably source a breakout board and make it work if you have the skillz.
Rebuilding an Adcom GFA555 II and am looking for currently available equivalents to:
Q201/Q251 - 2SC2912
Q301/Q351-2SA1210
Thanks in advance
Looking for a substitute 2sb649a and 2sd669a and was wondering will ksa1381, ksc3503 work. They are going in a NAD3225pe in positions Q413, Q414, Q411 and Q412. Thanks for any and all help in advance.
Hi, I'm trying to source replacement MOSFET drivers and outputs for a Sony TA-FA3ES. I can source the subs below but would appreciate confirmation these are ok or any alternative suggestions.
2SK2013 -> IRF610PBF
2SJ313 -> IRF9610PBF
2SK1530 -> IRFP240PBF
2SJ201 -> IRFP9240PBF
I'm not 100 % sure, but look into the SMD version of that transistor? They have higher gain versions.
Just realized that's not an 1845. I don't know if there is an 1815
Just realized that's not an 1845. I don't know if there is an 1815 SMD?
Yes, I could probably make an SMD work. Just need some ideas on where to start looking. No familiarity with SMD versions. I have tried a BC546 which spec wise should work, but no love.
