What is your application? It is doubtful the transistor is working at that level anyhow. Hfe is not everything...None have a 500 hFE so will not work for me, but Thanks for the info.
It is in a Denon PMA-2000r, in the amp boards, this what Denon calls out for.
TTC004How about one more replacement for 2sc3421 and as always Thanks in advance.
I'm not convinced that any of those need to be replaced. Are you sure it's not 2SA720? 2SC720 is a 500MHz RF transistor.I am gathering the transistors I need to rebuild the 2325 PH01 Buffer Board. I have KSC1845FTA to replace the (4) 2SC1345D,E. I have KSC2383YTA to replace the (2) 2SC1318Q,R, but cannot find a replacement on any list for the (4) 2SC720R,S at HH05,06,07,08. Can anyone help? Thanks
2SC1318 is only problematic, IME, in hot running Pioneer power supplies where it wasn't derated enough to last 50 years. C1345 is a pretty good high gain, low noise transistor that I generally only replace if faulty. I consider changing A720 to be optional if not faulty. If you don't need the voltage capability, KSB1116A is a good choice. For higher voltage applications, KSA1013 gets the nod. 1116A has more gain, 1013 has higher voltage and dissipation capacity.Thanks for responding. When you say, "any of those", are you referring to all (10) transistors on the PH01, or the (4) 2SC720 transistors. The first (6) are on the "10 Worst" list, so I thought they should be changed out. And to your question about 2SA720 or 2SC720-I don't know! I don't have it apart yet, but the SM says there are (4) 2SC720 on PH01. I know the manuals sometimes are in error but have not seen any info regarding this situation.
Thanks for the replyCiao!
The choice of the part to use depends on the location in the circuit. I would be more inclined to use a KSD1616A which is closer to the 2SC1417, but not a perfect macth.
KSC3503 would be better. Something with low CoB.I need to replace Q 5 ( 2SC1451 ) on a Pioneer SX-636 power amp ass'y AWH-034 .
I have KSC2690AY will that work or is there something better ? Thanks for any help
