Transistor Substitutions
And carefully look for something that has shorted. SOMETHING let a lot of current through there and took out your transistor. It is relatively uncommon for a transistor to fail like that. The 2SA726 is notorious for going noisy or failing, but not catastrophically shorting like that... at least not in my limited experience.
If you don't find the device that shorted, then you risk blowing the new replacement components.
Hi dlucy, you are right i need to change 2sc2360 too... its directly connected to 2sa1016 ... i found that MJ21194 is probably good substitution, or maybe mj21193g.:dunno::bye:
Which one is 2sa726 you mentioned in your last post? I couldn't find this one on the parts list...
Sorry, ivo. The pos about the 726 wasn't in reply to you. That's one of the issues of mixing threads.
The complement to the KSA992 you'll be putting in is the KSC1845. This will be listed on the datasheet for the KSA992. Datasheets are your friend. There are lots of answers in them.
So, look at the KSC1845 datasheet and see if it is a good substitute for the 2SC2362 you've got to replace. KSA992 and KSC1845 are meant to go together.
Sory for the delay!! i wasn't home. My bad - its 2sc2362. Q102 and Q152.
So im going to replace Q104 and Q 154 which are 2sa1016 with ksa992 and Q102 , Q152 which are 2sc2362 with ksc1845. I'm I right?
Thanks!!
Thanks, Doug! Sorry if I ask too much, but couldn't find sub for 2sa1210 and 2sc2912 they both are missing in the main list.
They are looking too bad in the board and the related caps are bad too...Ill take a look at the cross reference page too
The datasheet is available here: https://datasheet.octopart.com/2SA1210-Sanyo-datasheet-101591.pdf
That is a high voltage, high-ish gain (hfe), 1w or more application. Without knowing the actual circuit needs, the best match I found was the MJE15034 and MJE15035 complementary pair.
Anyone have a better match for the 2SA1210 and 2SC2912 ?
Checked up ksa1142. Found some different digits. 2sa1210 Ic=140mA, Icp=200mA - ksa1142 Ic100mA (?)
2sa1210 Vcbo 200v ksa1142 Vcbo=180v(?)
Ivo.
That's right! Ill replace the existing drivers with ksa1142 and ill post the result here
Any idea on a substitute for 2SD655E? I can't find anything about it on AK :dunno:
It's used in the post amp / muting section of a Yamaha T-2 tuner (TR411 and TR412).
