I know I'm way, way late to this party, but I tripped across this thread and figured I'd add my humble contribution in case someone might find it useful. This is a list I've been compiling over the years, culled directly from the hard work and resulting posts of those here that know what they are doing. I just filled in the blanks as I went along, using the suggestions that were researched here by those a lot more talented than me in this arena. Because of this, there may be errors or some inappropriate subs depending on what the circuit needs, but for the most part I think it might be a pretty decent jumping-off point for folks that are looking for substitutes. So far it has helped me out a few times.
If it is wholesale crap.... please let me know and I'll delete it.
Transistor substitutes
2SA484 KSA940TU
2SA493 KSA992
2SA497 KSA1013YBU
2SA561 KSA1013
2SA564AC KSA733CGB, KSA992FBU, KSA992FTU
2SA572 KSA992FBU
2SA569 KSA733
2SA606 2N5416
2SA628 KSA1013 *watch pin outs
2SA640 KSA992FBU
2SA663 MJ21193G
2SA671 TIP32CG
2SA673A KSA1013Y, BC327
2SA679 MJ21193G, MJ211195, MJ15004
2SA680 MJ21193G
2SA682 MJE253G
2SA684 KSA1220YSTU OR AYS
2SA706 KSA1220
2SA720 KSA1013
2SA722 KSA992FBU
2SA725 KSA992FBU
2SA726 KSA992FBU
2SA726 KSA992FBU
2SA733 KSA733G OR KSA992
2SA733 KSB1116
2SA747 MJ21193
2SA763 KSA992FBU
2SA798F
2SA814 2SA940TU
2SA823 KSA992
2SA899 KSA1220A
2SA905 KSA1220
2SA912 KSA1013
2SA981 MJ21193G
2SA1050 MJ21193G
2SA1051B 2SA1943
2SA1117 2SA1494
2SB507D-E MJE15031
2SB507P-E MJE15033G or KSA940TU
2SB526 2SA940 or TIP32CG
2SB527 KSA1220AYS
2SB528 2SA940, MJE15029,MJE15031
2SB530 MJ21193G
2SB536 2SA940 or TIP32CG
2SB537 MJE15031
2SB539 MJ21193G
2SB545 MJ21193G
SBD648A 2SB649A
2SB682 MJE15033G
2SB712 SC2073
2SC283 KSC1845 / KSC2073
2SC357 KSC2690
2SC372 KSC1845
2SC458 BC549, BC550, KSC1845, 2SC2240
2SC461 2SC945,KSC945
2SC461B KSD1616
2SC484 KSC2073TU
2SC485 KSC1845 / KSC2073TU
2SC497 KSC2383YBU
2SC608 2SC3858
2SC693 KSC1845
2SC732 KSC1845EBU
2SC734 2SC1815 or 2SC1845 0r KSC945
2SC735 BC337, BC637, BC639
2SC790 TIP41C
2SC793 MJ21194G
2SC828 2SC1845FTA
2SC829 KSC1845
2SC857 KSC2310YBU
2SC869 KSC2383/KSC2310
2SC870 KSC1845EBU
2SC871 KSC1845EBU
2SC905 KSD1616AGTA
2SC945 KSC945CLT or KSD1616A
2SC945A KSC2383
2SC959 2N3440
2SC984 KSC2383
2SC1060 KSD526
2SC1061 TIP31CG
2SC1079 MJ21196, MJ21194, MJ15003
2SC1080 MJ21194G
2SC1116 MJ21194
2SC1124 KSC2690AYS
2SC1175A KSC1845
2SC1212 KSC2690
2SC1213 KSC2383YBU
2SC1214 BC337
2SC1222 KSC1845
2SC1312 KSC1845
2SC1313 KSC1845
2SC1318 KSC2690 or KSC2383
2SC1318 KSC2690
2SC1328 KSC1845FTA
2SC1344 KSC1845
2SC1344 KSC1845
2SC1345 KSC1845FTA
2SC1345 KSC1845
2SC1364 KSC2383
2SC1384 KSC2690AYS or KSC2383YBU
2SC1407 2SD1207 (863-2SD1207T
@mouser)
2SC1416 KSC1845
2SC1438V KSC22316Y
2SC1451 KSC3503estu
2SC1451 KSC3503estu
2SC1515 KSC2310YBU
2SC1624 KSC2073TU or MJE15030G
2SC1647 KSD1616ALBU
2SC1649 KSC1845
2SC1708 KSC1845
2SC1885 KSC2383
2SC1904
2SC1915 KSC2690
2SC1919G KSC1845F
2SC2261 MJ21194G
2SC2460 MJ21194G
2SC2575 KSC2383
2SD188 MJ21194G
2SD234 512-KSD526Y
2SD287 MJ21194G
2SD313 KSC2073 or MJE15032G
2SD313 D OR E MJE15030G
2SD325 SC2073 or TIP31CG
2SD356 SC2073 or TIP31CG
2SD357 KSC2690AYS
2SD358 KSC2690, MJE15028, MJE15030
2SD370 MJ21194G
2SD381 KSC2073
2SD382 MJE15030
2SD425 MJ15022G 0R MJ15023G
2SD668A 2SD669A
2SD669 KSC3503
2SD712C MJE15032G
