My first ever tube build was a Triode Electronics ST70 kit. It went pretty well for a newbee. That was several years ago. Never had a problem with it. Until about a year ago. I fired it up and it died. As best I can recall it blew fuses , and arced the rectifier. I replaced the rectifier with a diy ss rectifier, which i had used successfully on that and other st70's. That overheated and smoked (literally) the power transformer. Im guessing i simply had a catastrophic transformer death. Dunno who made their transformers then or now. But as I recall I had a similar one crap out some years back on another amp.
It sat since then. I just got a replacement transformer from Hayboer. On the stock transformer wiring came out of both sides, on the new from only one side. Similar to the new replacements from Dynakitparts. It meant the wire run would be a bit different. No big deal, I hope.
So it is now done, biases up ok, most voltages are not insane, except on the 12au7. (It runs 2- ef86 and 1-12au7.) Pins 4 and 5 show 3.2vdc and pin 9 shows 3.4vdc. Triodes chart shows them at N/A, However a 12au7 pinout shows pins 4 and 5 as heaters and 9 as the tap.
There is also a wicked 60hz hum that first got my attention. i dont know if it is related to the 12au7 voltages, or if the different wire dress is causing that. I have checked the coupling caps on a heathkit cap checker at 450 volts. They show ok. Transformer wiring will be double checked.
I have no idea where to begin trooubleshooting this. Triode is known for less than stellar tech support, so I dont expect any help there.
Image 6032 are the voltages. 603 the original transformer wiring per their instructions back in the day, 8 or ten years ago, 604 wired with the new style transformer, and 606 with Triodes new instructions. Rev2 2011. So I was using Rev 1, even older instructions.
