Yes, touching the transformer does change the hum.
Yesterday I pulled the transformer. Gadgets early idea that the shielding might not be working had merit. There was no continuity between it and the chassis. Ive removed the plastic sleeves and have good continuity to the chassis now. Ill probably reassemble the thing today. As for the heater wiring, Ill ring them out, but they had been fine before. No hum. What is odd though, is that the old transformer had no bell on the bottom.
Also, looking at pics from disassembly, the brown/yellow and green/yellow wires had been twisted. Not so on the replacement installation. Ill do that as well.
Ive been putting together an order for new filter caps as well. I posted a thread on the diy forum. Gadget gave my some insight how to choose. Only trouble is one size is not available for 6 months. 390uf/250v 22mmx25mm snap-in. The physical size cant change due to the board layout.
Mr Bochie,it looks like the cap board section of the schematic is different. It calls for (8) of the above listed caps in positions c3-8, where i have only two , in c3 and 4.
Ll see if there is a schematic in my original paperwork.
