It was a "floating heater" arrangement with capacitor bypass, to allow the heater lines to self-elevate.St70 doesn't have center taps, it uses one cap to ground on each heater circuit. One winding per channel. At least that's what the old stock config is.
0.022mfd (C11 and C12)? Okay, I see it.St70 doesn't have center taps, it uses one cap to ground on each heater circuit. One winding per channel. At least that's what the old stock config is.
Sounds like an open on the signal ground to circuit board. Looks like a pair of wires from the board to each Jack. On the board the signal ground goes to circuit ground through a 10 ohm. Think I'd have a look at the jack
Gadget these suggestions were the key. I ohmed the input jack wiring and it was good. I looked at the board layout diagram to find the ground resistors and one had a little chip in it. Checked them both and they rang at 16 and 30 megs! Replaced them and voila!!! Hum gone.how's this for a test. Ohm check from the outer ring of the input jacks to pin 3 on each EF86. If all that path is right, it should ring out around 740 ohms.
Good job! Many years of reliable service.Gadget these suggestions were the key. I ohmed the input jack wiring and it was good. I looked at the board layout diagram to find the ground resistors and one had a little chip in it. Checked them both and they rang at 16 and 30 megs! Replaced them and voila!!! Hum gone.
Voltages are below. There are differences from Triode’s spec. Small tubes pins 4,5 and 9. They forgot about the heaters i guess.
One other question, the layout calls for 10 ohm , 1/4 watt for these resistors. They had supplied 1/2 watt. I have 1/2 in there now. Why the smaller size, and is it necessary? Could that have contributed to the fried transformer? Or a result?
Ill go through the thing soon, since its pretty messy after all this.
I cant thank you and Mr Bochie enough. I saw a quote somewhere that experience is what you get when things dont go as planned.
Steve
