Paging
@dr*audio, I have a request for your expertise after reading much of this thread over the past few weeks. I have a Technics SL-P8 (1984 build) cobbled together from two identical units. Used the drawer, power supply and control panel from one unit, complete optical block and both main circuit boards from another (so the optical block assy is mated to the same boards it always was).
New belts were installed and sled rails were cleaned and lubed with sewing machine oil. All limit switches making and breaking as expected. Loading and unloading work great.
I have it working, reads in TOC quickly and plays cleanly but has one screwball issue I can't nail down. On playing track 1 (innermost track of disc) it will frequently miss the first few seconds (between 2-6 seconds worth) such that I hear the playback start at a point past the true beginning. The time readout will reflect this accurately (shows 0:00 when initializing, but then time readout will jump to a point a few seconds in and the audible signal output reflects this).
Even more oddly, sometimes it will play perfectly from the start of the track without missing the first few seconds. This seems to be 10% or less of the time, most times it cuts off the first few seconds, but the missing anount of time varies between about 2 and 6 seconds. Clearly it has no problem making home potion as it gets the TOC read in every time.
Any thoughts? My first though was a dead spot in the sled drive motor but it never occurs after the beginning of the disc. I have a spare motor left from the donor unit (laser was on its way out and cosmetics were rough but had a good drawer assembly and PSU so I parted it to fiix the nicer of the two).
