I think they are sealed dr*audio.Yeah, those little crappy relays get noisy all the time. You can clean them with a piece of paper soaked in Deoxit, running it through the contacts.
No, the clear plastic top comes off. It's held on by plastic ramps on the sides. You have to desolder them before you can disassemble them.I think they are sealed dr*audio.
The only relays I see in there are the Zettler AZ830-2C-12DSE. Small black sealed relays seen in the pics.No, the clear plastic top comes off. It's held on by plastic ramps on the sides. You have to desolder them before you can disassemble them.
Oh. It's got valves in it. I would be looking at valve seating, too. Pull them out, check for oxide on the pins, plug them back in. That alone may be enough to re-establish good connection.
I suspect that was done during the mod upgrades that Partsconnextion/Chris did back in the day. Upgraded cap, clock. I bought the unit used around 10 years ago and have never been in there with an iron myself in that time.Looking at the right hand green, 1u 250V film capacitor, I see what looks like soldering iron burn (bottom edge & bottom RH corner). Has someone already been in there?
I see them. I think I've opened these in the past. You have to desolder them to replace them anyway so you might as well see if you can open them when you remove them. If you check Digikey you can probably find relays with the same voltage and footprint.The only relays I see in there are the Zettler AZ830-2C-12DSE. Small black sealed relays seen in the pics.
Good plan and thanks for the recommendation, much appreciated. I have the board out now and am going to start the desoldering of the relays. I'll let you know how it goes.I see them. I think I've opened these in the past. You have to desolder them to replace them anyway so you might as well see if you can open them when you remove them. If you check Digikey you can probably find relays with the same voltage and footprint.
Maybe these:
https://www.mpja.com/24VDC-DPDT-DIP-Relay/productinfo/32560+RL/
If it's a double sided board be patient and gentle so as not to damage traces and pads.Good plan and thanks for the recommendation, much appreciated. I have the board out now and am going to start the desoldering of the relays. I'll let you know how it goes.
Solderwick could be your friend here.Yeah; use the heat, suck & jiggle technique until the pins are free to move when cold. Don't want the vias pulling out.
Solder wick and patience all the way.If it's a double sided board be patient and gentle so as not to damage traces and pads.
I originally posed this question in the Yamaha forum but was asked tor repost here.
Okay, all this info is great, but I'm not a repair person, and when I do attempt to fix something it usually ends up in worse condition than when I started. That's why I'm here, hoping to find someone who will do the repairs for me. I'm not popping the top and messing around with the bits, so...
Can someone recommend where/who I can get my Yamaha CDX-530 looked at before I take a hammer to it and add it to our burgeoning landfills?
My usual go-to guy for vintage repairs doesn't work on CD players...
Sometimes it plays fine. Other times it will refuse to acknowledge a disk (that it played just fine 24 hours earlier) has even been inserted. It also skips on certain disks or hangs and just stops responding. It's not consistent in any of this behavior. Some days I can have a 6-hour listening session with no issues, and then there are days (like today) when it just refuses to cooperate.
Thanks in advance!
Well... I installed a replacement relay in the left channel and no improvement. If anything it is a little noisier. I have checked resistors in circuit and all measure close to the right channel. Praying it's not the DAC. Never going to find one of those.If it's a double sided board be patient and gentle so as not to damage traces and pads.
I can't understand the nature of the burn spot around the one of the screw that hold the MB
The lights are all LEDs. Just go to Digikey and search for LEDs that are through hole parts of the same size, shape and color. The longer lead goes to the positive side, 5V.Good morning @dr*audio I am looking for replacement lights for my Sony CA8ES cdp. I struck out with Vintage Electronics, they had no info for that unit. No help on the “bay or the usual suspects. Any idea which would be the correct replacement bulbs/lights for this model? The only functioning light is the Play button, the display window and power button are dark.
Thanks for any info you could help me with.
