CD player only focuses and starts playing upside down !
Hello, I am starting repairing a nice Denon DCD-7.5 CD player with the Sony KSS-240A laser. 1991 vintage, cosmetically in great shape, unknown usage. Upon disk loading you can hear the laser hunting, but it does not apparently focus, and thus not spin. Picking up and turning the whole player physically upside down while loading a disk, carefully between the CD being held as part of the loading and the focus hunting, will get it running nicely !. Then, even turning the machine back the right way up, it plays great, till the disk is ejected (and thus presumably has to refocus next time). CD seems to be held secure, but with the disk out the spindle motor table seems to have vertical play of 1mm or so.
The KSS-240A to the left of the easy to see 3 pots has what looks like 6 vertical test points - can one of those be used for the RF eye signal instead of taking the drive out and soldering a wire to the RF test point ?. I could not find a layout/detailed schematic for the KSS-240A itself.
Have some CD experience though not seen this before, done some research, wondering if the fault is :
A) Worn bushing on the spindle motor ? thus the disk table is ~1mm too low (explaining why it can focus upside down ?), and I should raise the table carefully ? so like 2mm above the laser.
B) Maybe some spring ? that raises the laser assembly upon disk insertion has grown weak or sagging ? (so laser closer to the disk when turned upside down), and how do you adjust for that ?.
C) Sled rail ware ? (unlikely ?) - how fix/compensate ?.
D) Maybe the lens suspension has given up ? but the lens does bounce a bit when carefully pushed, and it's light weight, and rather not get a modern KSS-240A copy if the original, though 32 years old, is OK.
E) Or do I just go ahead and try increasing the laser current a bit ? (with the risk of burning out a good original lazer).
I have cleaned the lens & table, otherwise not taken apart yet. Sounds like a mechanical issue, thus would like to fix mechanically, appreciate ideas, thanks
