dr*audio
Fish fingers and custard!
Don't remove the disc table, the height is critical. Usually there is enough slop in the motor shaft so you can lift it slightly to get the needle under the disc table neck, but if you can't, just apply the oil where the disc table neck meets the plate and the oil will wick in where it needs to go.Sony CDP-311
I am trying to oil the disk table motor bearing, I'm using a hypodermic-like needle to apply the oil. Below the metal plate is the motor which is flush against the plate so the needle can't get in there. Above the plate, the black plastic on which the table sits is too close to the plate for the needle to fit there either and I don't think I can find a smaller circumference needle. I don't have an angled driver to get at the motor screws to possibly drop the motor slightly so that I could get in that way but with the black plastic part holding it above I don't think I'd get enough clearance anyway. The only option I can see is to remove the table and plastic part. The service manual doesn't say how to do this removal. How is this done, or is there another option for accessing the bearing. I realize that removing the table could ruin the table height after replacement but again I don't see any other option.
