Good call on the big IMF's - might just be the least expensive way to get really low and accurate bass reproduction (without using a sub).
jblnut
I am not disputing the idea that low frequencies can, in certain circumstances, give someone a sick stomach.
There is a difference between making something for the purpose of producing low frequencies, and a poorly designed or poorly installed air conditioning unit that accidentally makes noise at such frequencies (that air conditioner might be producing even lower frequencies; I don't suppose you measured what it was doing, did you?). Just like noise at higher frequencies is not the same as music at higher frequencies. You are not claiming that that air conditioner sounded like a pipe organ, are you?
This or the KEF 107's, depending on price. We had a member here @canuckaudiog who had both. I think IMF RSPM MKIV and the KEF 107's. I think he ended up concluding they were a bit of a "draw" for his preferences (don't want to put words in his mouth though). I've never heard IMF speakers but after hearing his impressions of those vs. the 107's, I'd like to!
I've seen the KEF 107's as low as around $1k (unless you get REALLY lucky...I did see one pair around $500 and one around $800)...but I've also seen them as high as $2200.
The only pair of the IMF's I was looking at were $750.
So yeah they may be a tad cheaper than the 107's.
I'd give a hard look at either of those for the $1k or thereabouts range.
Really?
And there is nothing wrong with the Behringer amps. If you need to keep moving the goalposts in order to make it seem like that QSC really is the ONLY option, which was the crux of your argument against doing "expensive" DIY powered subs in the first place, carry on. I've already shown that one amp, tested out independently, can do over 1200wpc @ 8 ohms. Plenty of people have used the NX6000/Inuke6000DSP combo and been very happy with it. And I've shown that dual mono Crowns would give more wattage for for less money, if a person is adverse to using Behringer. I'm guessing it's now down to the aesthetic of having just ONE amp involved? Maybe the color of the amp, or the THD at 1khz, is next?
In any case, anybody who has been reading the thread knows, by this point, that there are plenty of options that aren't as expensive as you claimed they had to be. That was what I wanted to point out, so this conversation is really just spinning wheels, at this point, from my perspective.
When I talked to Rita, she said that the actual components (e.g., capacitors) in the Sunfire physically shake themselves to death from the inside out. I imagine that a "lesser" sub may not subject its internal guts to such pressures/abuse.
At least six factors that need to be considered when evaluating claims of frequency range:
1. Volume level: Almost any speaker will play 20Hz, just not very loudly. Pad down the rest of the range to match, and voilá! How loud do you need that 20Hz? Look at the equal-loudness curves, that 20Hz needs a pretty high volume to be noticed as a *tone*. And that volume will probably be limited either by power handling or excursion.
2. Duration: related to the power handling mentioned above, and to power *compression*. It might take minutes (or even seconds), but the heating of the voice coil will drastically increase its resistance, and thus the output of the woofer.
3. Cutoff slope: 20Hz at -3dB? -6dB? -10dB? Not everybody specifies the same way, if at all. And is it booming above cutoff? How far down is it at 30Hz? 25Hz? 15Hz? See the equal-loudness contours again...
4. Distortion: When the driver approaches the magnetic or mechanical limits of excursion, distortion shoots way up. That distortion manifests as extra frequencies not in the original source. Once again, equal-loudness means the distortion will be much more audible than the fundamental note! The one bright spot is that our brains can extrapolate a low bass note from higher harmonics, even if we can't directly hear it.
5. Directivity: Not so important for low bass in small rooms, but certainly outdoors. And important for the tactile aspect. For the upper limit, extremely important. After all, how useful is "flat to 30kHz" if everything above 5kHz is delivered on a pencil-width beam?
6. Distance: Easy for any speaker to play even difficult low notes, if your ear is right against it. And also very important for bass tactile sensations.
Even if you had stereo speakers "flat" down to 20Hz, they would make no sense. Whatever is reproducing low bass (below, say, 80Hz) needs to be optimally located to provide the flattest room response. Having two such speakers, you can do that much more easily. However, where those speakers will need to be located for best bass response, will probably be nowhere near where speakers need to be placed for best higher-frequency sound and stereo imaging. You need separate subwoofers that can be located independently of the main stereo speakers. Then it's semantics as to whether the subwoofers and their amplification are parts of the main speakers or not, just because they happen to be in usefully separate cabinets.
The more practical metric of the bass extension of mains speakers is: How well do they integrate to the subwoofers? Can they match in desired playback volume? Play well enough to an octave below the crossover frequency to the subwoofers? Do phases/group delays match up?
Not many that can do , this is one of them it's the IRS beta 15hz-45khz servo controlled low end is far superior to what I have heard any other speaker/sub do.
My original Carver amazing loudspeakers were flat down to 16 Hertz.Are there any true full range floorstanding speakers? I don’t mean ones with a built in powered subwoofer. I mean all passive that will do 20Hz-20kHz +/- 3dB. I’ve owned Pioneer HPM-100, Cerwin Vega VS-120, Realistic Mach One, Realistic Mach Two, and Optimus Mach Three. None of those come close to getting down to 20Hz. I would assume it would have to be a large sealed enclosure. I’ve never heard any of the big vintage JBL with 15” woofers but every JBL I’ve seen is ported. I’ve heard Klipsch Heritage and KLF. The big CV with 15” woofers too. Am I gonna have to build huge sealed cabinets with dual 15” woofers in each and a horn D’apolito style to satisfy my wants?
