Just to complicate things...
The real kicker in this is that most people believe there is a "stream" of electrons actually "flowing" through a wired circuit, much as water flows through pipes. That's a great way to visualize and think about electrical current, and it works in normal situations to explain how things work and predict what happens in circuits.
However, ask a good physicist and they'll explain to you that this is not what is ACTUALLY happening. It gets complicated, but the truth is that there is a shifting interaction of electrical potentials, and (usually) not an actual "flow of electrons." When current flows through a circuit, you don't actually have tiny electrons jumping from atom to atom; you have electrical potential shifting within and between atoms, to produce the same net effect.
It's kind of like those devices with large ball bearings suspended one against the other, where you raise up the ball on one end and let it fall. It hits the row of balls and the ball at the other end flies up. To an observer who couldn't see the balls in-between, you'd think the ball dropped in on one end, and "flowed" through and flew out the other end, or at least that each ball sequentially replaced the one beside it, to push the end ball out, but actually none of the balls was shifted in position; only energy was passed through them. Similarly, the electrons don't actually move or jump from one atom to the next when electricity flows; they shift their relative position and thus create an imbalance in potential across the atom, which shifts the charge (potential or position within the atom) of the next atom, and so on down the line. It's a transfer of energy that takes place almost instantaneously, not an actual flow of electrons.
Electrons (like any other subatomic particles) CAN be torn loose from atoms and made to "flow" in a stream --that is what particle accelerators/colliders do. Under such circumstances, the speed of the free electrons can be altered (they can be accelerated or decelerated). But in normal electrical circuits, that "flow" of electrons isn't what is really happening - it just seems like it.
Now here is the fun part: at least some vacuum tubes act like little particle accelerators, and DO rip electrons off of atoms and send them across to another set of atoms!
So there are two different processes at work, in these two different situations.
