Once the feedback signal is more than 180 degrees out of phase with the incoming signal you get positive feedback which will make the amp unstable and motorboat (perhaps ultrasonicallly). Steps are usually taken to limit the bandwidth of the amplifier to ensure this does not happen.
My point above was if the delay was audible (around 5ms) then negative feedback would would induce oscillations using a 200hz signal.
Yes, I understand both of those things. Obviously NFB occurs over a vanishingly short time interval, and for it to work in audio gear that time delay has to be on the order of some small number of degrees (or fractions of a degree) on a 20kHz + signal. Obviously this will not be audible as a time delay. I was extrapolating your comment because I've been wondering just how long the time delay is in a typical amplifier, and what unintended effect that has on the signal amplification.
In a tube amp the global NFB is taken after the OPT, so if the conductor length and phase issues are part of the situation. I don't know how to calculate it either.
Consider this:
with the speed of light at 14,989,622,900 cm/sec and assuming the speed of the signal through an amp averages half of that, 14,989,622,900 cm/sec then the delay for 100 cm of travel is 6.67E-009 sec. At 40 kHz that amounts to .0025% (25 ten thousandths) of a single wave length. How much voltage change could occur in that small a time period. If I recall correctly the formula for finding the voltage at any moment in a sine wave is:
V = Vp*sin(2*pi*f*t) (Vp = peak voltage, f = frequency, t = time)
If this is true then it follows that the maximum voltage change (and therefore the greatest effect the feedback could have on the signal) is when it crosses the 0 voltage point - the point where it is changing the fastest. Most listening takes place at low power levels because even 80 dB is loud in a home but lets calculate this for a 10 Watt signal into an 8 ohm speaker. The rms voltage for this would be found by using p=v^2/r.
10 = v^2 / 8
v^2 = 10*8 = 80
V = sqrt(80) ~ 9 volts rms
V
peak = 1.414* V
rms
V
peak = 12.73
Now we have all we need to calculate the voltage change induced by the delay of 6.67E-009 sec.
V = 12.73*(sin(2*3.14159*40000*6.67E-009)
V= .02 V
OK. We have a .02 V (20 milivolts) error at 40 Khz max. What percentage is that:
.02/12.73 * 100 = .168 % or less then .2 % distortion. At double the hearing of a human being and at the most critical point in that waveform.
Some things to keep in mind:
1) This used a fairly long circuit - 1 meter. Total circuit length is probably less then that in a well designed amp, including feedback.
2) It used a fairly low speed for the signal through the amp, .5 C
3) It used a frequency of double the recognized max that most people are capable of hearing.
Quite frankly the magnitude of the distortion quite surprised me. I expected it to be even smaller then this.
Just food for thought - cause sometimes I like working on this kind of stuff.
Shelly_D
