Tubes electrons "faster" than solid state?
Let's back up a moment and review the banging balls, BBs in a straw, etc attempts to explain the fast propagation of charge in spite of the slow propagation of charge carriers in a conductor...
First off, let me apologize for not distinguishing in the original question whether the 7x faster factor applied to the speed of the charge carriers or the speed of the charge. As I saw it, it seemed to be referring to the speed of the charge carriers - the electrons themselves.
Now it has been suggested that the charge itself moves on order of half light speed in a conductor, but the individual electrons within the conductor have a net drift on the order of cm per hour.
The net drift speed is the average of all the motions in all directions; only a small subset of those directions are in alignment and moving from point A to point B (A and B being the two ends of the conductor).
The problem I see with the banging balls / BBs in a straw concepts is that in these examples where the balls/BBs represent the motions of those electrons aligned and moving from A to B, their individual speeds are IDENTICAL in value to the speed of mistaking the first ball/BB to have made the entire trip. These analogies do not demonstrate that the electrons don't travel fast, only that they don't travel the whole distance. Their speeds are the same as if they did.
So the individual electrons in a conductor moving A to B DO travel the same speed as the charge, they just hand it off in doing so in order that they don't go the whole way.
So I'm thinking that in the tube, the electron speed and the charge speed are equal - and in this case they ARE going the whole distance. The hand off idea with the balls and BBs does not apply here.
But in SS, the individual electron speeds are the same as the charge speed, but each electron is only going a small part of the distance before handing it off to the next one.
In both these cases I'm thinking of only the electrons that are moving in alignment with the geometric path from A to B, not the ones going willy-nilly all over the place - I think the net drift of the carriers as a group is a red herring here.
With that "clarification", the question now remains, is there a difference in the speed of the A to B aligned carriers in SS and tubes, and won't that determine the charge speed?
I have to imagine that the handing off from one electron to another is caused by the interaction of one's electromagnetic field with the next one, caused by moving toward it. Since the EM field is mediated by the exchange of photons, it is not clear to me which would be faster... In the tube, the electrons may be traveling at half light speed, but in the SS the numerous hand off gaps are being mediated at full light speed.
If the innate speed of the aligned (A to B) moving SS and tube electrons were the same, the SS would be faster by whatever fraction of the linear distance A to B was comprised of full light speed hand offs of charge.
This would lead me think that if the 7x figure is an empirical result, the actual speed of the SS electrons compared to tube electrons must be even slower because the solid state electrons enjoy a full light speed charge hand off advantage.
So an analogy would be:
The tube electrons are like people riding bicycles for 10 miles.
The SS electrons are like people doing a relay race with bicycles for 10 miles, but they each get to use a car for the last section of each leg.
Kinda begs the question of why you need monoblocks, don't it?:smoke::yes:
Does it? Besides channel separation, with monoblocs you get a better power supply setup, since each amp has basically the same power supply setup as a stereo amp would? I am talking quality amps from the same manufacturer.
Consider this:
with the speed of light at 14,989,622,900 cm/sec and assuming the speed of the signal through an amp averages half of that, 14,989,622,900 cm/sec then the delay for 100 cm of travel is 6.67E-009 sec. At 40 kHz that amounts to .0025% (25 ten thousandths) of a single wave length. How much voltage change could occur in that small a time period. If I recall correctly the formula for finding the voltage at any moment in a sine wave is:
V = Vp*sin(2*pi*f*t) (Vp = peak voltage, f = frequency, t = time)
If this is true then it follows that the maximum voltage change (and therefore the greatest effect the feedback could have on the signal) is when it crosses the 0 voltage point - the point where it is changing the fastest. Most listening takes place at low power levels because even 80 dB is loud in a home but lets calculate this for a 10 Watt signal into an 8 ohm speaker. The rms voltage for this would be found by using p=v^2/r.
10 = v^2 / 8
v^2 = 10*8 = 80
V = sqrt(80) ~ 9 volts rms
Vpeak = 1.414* Vrms
Vpeak = 12.73
Now we have all we need to calculate the voltage change induced by the delay of 6.67E-009 sec.
V = 12.73*(sin(2*3.14159*40000*6.67E-009)
V= .02 V
OK. We have a .02 V (20 milivolts) error at 40 Khz max. What percentage is that:
.02/12.73 * 100 = .168 % or less then .2 % distortion. At double the hearing of a human being and at the most critical point in that waveform.
Some things to keep in mind:
1) This used a fairly long circuit - 1 meter. Total circuit length is probably less then that in a well designed amp, including feedback.
2) It used a fairly low speed for the signal through the amp, .5 C
3) It used a frequency of double the recognized max that most people are capable of hearing.
Quite frankly the magnitude of the distortion quite surprised me. I expected it to be even smaller then this.
Just food for thought - cause sometimes I like working on this kind of stuff.
Shelly_D
Thanks for doing this analysis! I haven't gone through it all yet, but the conclusion I draw from it is that there is the possibility of a calculable deleterious effect of NFB in audio gear. I say this because I think the analysis, while good, is still a simplification. With the simplifying assumptions the amount of distortion is probably not significant, but it is close to being significant. If more things are taken into account - like the effect of the circuit's capacitance and inductance on the phase relationship between input and output signals - then perhaps the distortion becomes of a more meaningful magnitude. It would be fascinating to do a real circuit simulation. I wish I knew how!
Edit: I just re-read the post, and I think for a tube amp 1 meter is way too short for the circuit length. How long is the wire in the OPT? And how do you figure it anyway... the feedback signal is taken from the secondary, which is inductively coupled to the primary with interleaved windings. It's not obvious to me that the entire length of both sides should be used. Possible half the primary and half the secondary would be a decent compromise?
That is an interesting point for the OPT. I have no idea what to do with that length. Is it long enough to make the one meter length incorrect? I just don't know. Should the length of the wire be considered or is it a device? Don't know that either. Starts to make my head hurt.
Suffice it to say I reside in the camp that thinks negative feedback when done correctly can do many good things for an amp and tend to keep it connected in devices I muck around in.
Shelly_D
Shelly_D
I fully agree with this, though I'm curious about the compromise involved when using negative feedback (and there's always a compromise). I'm not smart enough to fool with changing the feedback loop in any of the devices I muck around in except in guitar amplifiers where "anything goes" more or less.
