? Tubes vs. SS Class A
crouse
Poorly known member
I realize the answers will have to be generalizations, but which do you prefer, the sound of tubes or the sound of solid state Class A amps? And why?
Thanks
Are you asking Class A (SE or PP) tubes to Class A SS, or any kind of tube topology to tube SS?
I am pretty devoted to Class A, single-ended vacuum tube amplification using triode output tubes with directly heated filaments (DHT SET).
Why? With appropriate loudspeakers, it sounds like real life.
I probably should have just asked about the sound quality of solid state Class A, as there are plenty of descriptions of different tubes. I'm thinking I may try either tubes or SS Class A somewhere down the road.
Thanks
I just had my first real listen to a class A Yamaha this evening this evening but have no experience at all with tube. All I can say that little Yamaha CA-1000 made some Dahlquist DQM-9's pop with detail like crazy. (Brought the vocalist to stand right there in front of you and retreat right back for the guitar solos....incredible.) Sure the mix had most to do with that but the clarity was dynamic and those speaks did it justice!
Nothing wrong with the sound of a good tube amp when the tubes are in good repair, and few SS amps sound as clean; but SS is catching up:
http://www.ultraaudio.com/index.php/equipment-menu/300-first-watt-j2-stereo-amplifier
Summary
I expected Nelson Pass’s First Watt J2 power amplifier to be almost as good as a good tube amplifier, but it wasn’t -- it was better than most tube amps I’ve tried. It’s possible to find better-sounding tube amps, but you’d better be prepared to part with a lot more cash.
A Tube DIYers once told me, for large orchestral / symphony music listening, we need to go to SS Amps. Is it true in general, tube-lovers ?
A lot depends upon what speakers you are driving. Tubes produce voltage, but are not typically able to produce a lot of current. SS amps are better for driving "difficult" low impedence speakers. Also, if the speakers are inefficient, they will require a lot more power to achieve the output level that you may desire, and most tube amps are lower powered. You can buy big ones, but be prepared to spend some $$$. For any system to sound good, you have to have "synergy" amongst all the components.
Evaluate your needs... power, current, etc. and do some listening...
I have really low impedence "difficult" speakers, so I use SS amps, but incorporate tubes into the front end via my preamps and sources--kind of the "best of both worlds" for my needs/preferences.
I like 2a3 SETs for full range main drivers but my choice for large woofers are class D plate amps. The Topping t-amp drives the tweets in this 3 way.
picture.php
I believe it's class AB
http://www.classicaudio.com/value/yam/CA1K.html
I didn't respond to the OP because I'm not sure I've ever heard a class A SS amp. Not many around. The only ones I can think of are the Pass Aleph stuff.
What else is there, class A SS?
EDIT: Oh yeah, I forgot about Monarchy. Thanks jimfet
No, It depends on to many factors to make a broad assumption like that. I have owned High powered McIntosh SS gear, lower powered McIntosh tube gear, and now higher powered McIntosh tube gear. I have achieved excellent results with all of my systems. My current tube system did an excellent job of bringing out the soundstage in a very good recording of Mahlers 2nd this weekend. I don't feel the need to rush out and get a SS system any time soon.
For the OP's benefit - if you haven't heard even a cheap "Class T" (Tripath chipset - or whatever the current equivalent is) amplifier; it's well worth a listen to one.
I have one of the uber-cheap ones from Parts Express and it holds its own against SE 2A3 (and is in fact noticeably more extended in HF - albeit a tad fizzy - compared to the SE 2A3 amp I use as my daily driver).
There are fine sounding ss Class A amplifiers; AKer Beemer has lovely older Mark Levinson (real Mark Levinson) high power class A monoblocks that are just superb).
My Krell and Levinson amps are pure class A SS, but there are a lot of "new class A" or A/AB amps out there that operate in pure class A for the first few watts and then go to AB.
There are too many factors to consider to make such a generalization. I dont listen to orchestral-type music, but I do listen to primarily electronica, and my 6B4Gs have no trouble keeping up. Big output transformers will produce deeper bass, as well as larger efficient drivers in a proper cabinet. The type of the components used will determine the end result.
I just received my first Class A amp Friday, a Monarchy SM 70 Pro and teamed it up with my Altec 19's and I am real happy with the results after running my tube mono-blocks for many months. The Class A has a nice smooth, warm sound & tight bass. Definitely the best sounding SS amp I've tried with the 19's. I'd like to try a SET sometime.
