Not really. :tears:
From what I've read, they used ferrofluid in the VC gap, and when it starts to dry out, the output goes with it. It turns into a sludge, and limits the VC travel, hence the low output.
I know you don't want to hear this, but once this happens, the tweeter is toast. Too bad, as they are really nice tweets. Hue @ Human (
http://www.humanspeakers.com/index.htm) sells new replacements. He might even be able to rebuild yours, but I'm not sure on that point. Give him a call and ask. If he can rebuild, do both so they match in output. Also, if you haven't, change out the cap. It makes a difference. :thmbsp:
BTW, which model box and tweeter do you have? Red ring, Gold ring, Masonite? I do see them on e-Bay from time to time. It might be worthwhile to do a search.
If you go with replacements, I'd replace both. If one went bad, maybe the other isn't far behind. My 2 cents.
I'm a BIG EPI fan. 2 sets of 100's, a set of 2.0's, a set of A120's, and spare parts, just in case.
Good Luck. Keep us posted.
