ImWolf
Sansui 9090DB Serial No. 826100046. After poking around the data bases here, this might be the oldest one on the AK site? (not necessarily a good thing). I started describing this receiver on a previous (Repairs & Servicing in Washington State) thread, which has now been deleted entirely.
After 3 months with the most highly recommended tech in my area, he gave it back to me with multiple issues and told me never to bring him another one. $240 for some bulbs and some cleaning? He told me along the way that the Dolby function had been by-passed because he saw “about 10 jumpers added”.
1) Channel Dial Illumination. The lighting at either end of the dial
keep turning on/off at will. Tapping on top of the cabinet or pushing
on the face sometimes affects the lighting.
2) Left and Right channel output is inconsistent. Mostly a problem
with the Right channel going out, and resumes when I rotate the
Input Selector Knob.
3) Tape Monitor Functions Crippled. While listening to Radio or Aux
input, pressing one of the Tape Monitor buttons should bypass the current input, but does not.
4) Dolby function is messed up. I usually leave the Dolby knob at the
OFF position, but when I do turn it to other settings the audio will
either stop completely, or change tone/volume a lot.
5) Bass, Trebble, and Midrange filter switches and knobs barely make a difference to the sound of what I'm listening to at the time.
I contacted a 2nd tech in the vicinity describing the above, and he wanted nothing to do with it. Ended up taking it to another tech and just got it back home a few days ago. After inspection he e-mailed me estimates;
Needs new
1 PUSH SWITCH CIRCUIT BOARD
2 Dolby board
3 Filters
4 input switch
5 rewiring
Repair cost could be about $800
Or you can use Radio and aux input only.
Lights we will replace it.
Sound we can fix it and replace capacitors (filters)
Repair cost could be about $285-$345
When I asked him about what needs to be rewired, he said there were wrong connections, and connections missing. Also, the 36 contacts between the Dolby Switch & daughter board had grey ribbon cable that didn’t look right.
I know there aren’t any NEW parts he mentioned to be had, and I didn’t want to go for either of his quotes for his idea of a full, or partial repair.
To start with I’m going to post a bunch of pictures, and hopefully you guys who are very familiar with these might spot something that doesn’t look right. The only things that jumped out at me are that the bracket some units have to support the F-2624 Driver board is missing (not sure it ever had one), and 4 of the screws (closest to the faceplate) that hold the Tuner Tray down are also missing.
Then, I really want to remove the Tuner Tray and take some photos of what’s under there to get an idea of what these two techs are talking about relative to added jumpers or strange wiring.
From what I’ve studied thus far, it looks like I would only need to pull out 3 plugs that are side by side connected to the F-2653 Eq. board, and possibly the one yellow wire connected to the “Front End” with a small spade connector. The faceplate appears to be attached to the Tuner Tray with 2 small screws on top, but it looks like I can just pull off the tuning knob, and then slide the tuner tray back after removing the necessary screws?
If for some reason however it would be safer to remove the faceplate first for reasons I’m ignorant of, please let me know. Also, would it be better to do this with the unit laying flat, or on it’s side like others choose to do?
Needs new
2 Dolby board
3 Filters
4 input switch
5 rewiring
