Unique & Distinctive Speakers
When you absolutely must take your speakers with you, and you want to make an impact wherever you go, and you want to be able to go anywhere...
Yeah, I have that all the time!
So where can I get me a pair of these "bass dumpsters"? Might come in handy for your average rouge outdoor Covid party's as well..
Deep Breath Marble speakers by Care Orchestra (Italy)
...audiophile 2-way bass reflex speakers constructed of Italian Marble (these would look soooo good in my home along with my other Italian marble tables)
https://www.careorchestra.com/speakers/marble-speakers/deep-breath-marble-edition/
Those put me in the mind, of thinking about these- the Acora SRB:
Made of granite. That little speaker is 55lbs!
They are quite expensive ($15K a pair), but they are absolutely astoundingly good. That little speaker shouldn't be able to do what it does, by all usual rationale.
Regards,
Gordon.
I wonder how that sub works?
It’s a rotary subwoofer. Uses a couple of lightweight polystyrene carbon fiber vanes that rotate back/forth in that housing. It’s 12” in diameter and has the output of three conventional 12” woofers. I still have the September/October 1996 Car Stereo Review test report.
Speakers made of cement are very prone to chipping — the corners are specially vulnerable, then the sharp edges. I had two sets, from different m'frs, and both chipped. But they do their assigned task: totally inert acoustically.
I imagine that concrete can be mixed with some additives (such as a plasticizer) to lessen brittleness and chipping, but one never knows if the speaker company thought of this when they spec'd the cab. I have not tried them, but I can imagine the acoustic inertness to be a strong point for speaker designers like yourself. I have some old Infinity SM-122 studio monitor towers that have awfully thin cabinet wall structures (i.e., they do not pass the cab knuckle test), I wonder if the designers took this into consideration when they designed them as they sound fine (or maybe it was simply cost cutting). They are not even close structurally to my older Infinity Quantum 4 towers with thick wood with strategic bracing added. Anyway, while we are on the subject of concrete speakers...
HEVI Concrete modular Speaker
Two speakers facing the organically curved plate directs the sound outwards
Rf78dc854c88d2e4b4a6ce041de1924a7
According to an article in the UK mag HiFiNews circa 1990, Stevie Wonder and Elton John both used concrete speakers as their studio monitors — made by, if I recall, QLM. I had a pair and they were incredibly neutral, but needed a lot more power than the little NAD 3020 I was using.
Paradigm Persona B (most affordable of the current Persona line)
- 2-driver, 2 way bookshelf bass reflex
- +/- 2dB from 60Hz - 45kHz
- 92 dB room sensitivity (89 dB anechoic)
- LFE: 24Hz
Devialet Phantom I 108dB Opéra de Paris
Wireless powered speaker system with Apple AirPlay® 2, Bluetooth® and Wi-Fi®
  • built-in Wi-Fi for wireless music streaming when connected to a home network
  • built-in Bluetooth
  • Apple AirPlay® 2 lets you stream directly from an iPhone® or iPad® and ask Siri to play Apple Music®
  • Universal Plug 'n' Play (UPnP) high-resolution streaming
  • 1 titanium tweeter, 1 aluminum midrange driver, 2 aluminum side-firing bass drivers
  • high-resolution playback up to 24-bit/48kHz resolution
  • amplification: 1100 watts RMS
  • frequency response: 14-27,000 Hz (-6dB)
  • maximum volume: 108 dB SPL
  • total harmonic distortion: 0.0005%
Syng Cell Alpha (With Table Stand)
Powered speaker with Wi-Fi and Apple AirPlay®
  • circular Triphonic array: three horn-loaded midrange drivers with concentrically mounted tweeters
    • 120° spacing for multi-directional coverage
  • dual 5-1/4" force-canceling subwoofers for room-filling bass
    • one upward-firing woofer and one downward-firing woofer
    • back-to-back force-balanced placement cancels out unwanted vibration
  • individual Class D amplification for each driver (eight total)
  • frequency response: 30-20,000 Hz (±3dB)
  • up to four speakers (sold separately) can be used in one room or in a multi-room configuration
  • multi-zone source selection and speaker control via Syng Space app
    • available for Apple mobile devices; Android support coming soon
  • built-in dual-band Wi-Fi for streaming music
    • supports Spotify Connect and Apple AirPlay 2
  • dual USB-C audio inputs
  • AC power required
Green Mountain Audio drivers are mounted in reformuated marble poured into molds and then either sprayed black or wrapped in wood to help with the WAF factor.
I can't find any naked pictures of them.
That looks to be a very interesting system. What are all the components?
I restored the speakers a couple years ago, Infinity RSII
Amp is a B&K 4420 modded my musical concepts
Pre is a harman kardon citation 17
Phono pre is a vista audio 2
TT is a custom Denon dp 1000 (least amount of electronics) with a jelco 10 inch
Cart 2m black
ha, now that I wrote this I forgot it’s all in my sig…
