Sort of similar paths here, but once I heard horns, even though I could hear the issues with them, I know I'd never really be interested in cones and domes again. My Khorns eventually evolved to a pair of LABhorns for bass (corner loaded), long hypex midbasses 'L' shaped, trax upper midbasses and round trax MF/HF with BMS4590. Never quite sounded integrated as I couldn't sit far enough back, but I was happy with the compromises.About 10 years ago, I heard a set of speakers that pretty well changed my opinions on everything I knew about speakers. Prior to hearing them, I was convinced that cone/dome speakers were the way to go. I had heard plenty of horns over the prior 10 or so years, never really hearing one that really did it for me. I found them a bit honky, shouty, or just plain ear splitting. Many of those I heard were very well respected, and many did some things very well. They never ran short on dynamics for instance, which is a huge plus in their favor, but none of them excited me much. Klipschorns, Lascalas, Edgar Horn Titans, old Altecs, and even some front and back loaded horns using dreadful drivers like Lowthers.
I wanted a set then, and faffed around, and by the time I emailed to buy, Nick had shut down.At the time, I was a member of the basslist and Thomas Danley introduced the unity horn, and offered it to the basslist via Nick McKinney at Lambda Acoustics.
I heard William Cowan's Unity's last year and they were bloody amazing, and I'm not impressed easily.After hearing the Unity's, I had finally heard what I had always hoped to with horns, no odd colorations. They sounded like cone/domes at low volume levels and as you turned the volume up, they just kept on sounding like that. Very smooth, extremely detailed, and even at very very loud levels, there wasn't a hint of compression. I was hooked, they had dynamics, detail, and smoothness?! The basic idea of the unity horn was to create a 2 way horn system with the mids and highs sharing the same horn. The Compression driver is attached at the back of the throat and the mids get attached on the walls of the horn and are placed in such a way that the horn acts as a point source from 300hz up to the frequency limits of the compression driver. In the case of the Lambda Unity horns, they were square conical horns, but the unity principals can apply to other flare rates, as well. The lambdas used a 60x60 flare to near the outer edge where it transitioned to a 90x90 horn near the terminus. It's a constant directivity horn, as well.
Wow, he keeps turning up more. I bought a pair with a full set of drivers from him a year ago, and Roger (in Melb, Oz) bought another set a couple of months back. We/ve both got AE TD drivers to match them with, in my case a quad of 15X and Roger, 15S. We're both using the passive MF/HF xover on William's page, and active LF/MF.A few months ago, Nick decided to sell off some B-stock sides for the unity horns for a good price so I decided to jump on the opportunity.
Here is the two pics I got of mine alone before the camera died.What do you use for midrange drivers?
DE25-16. They came as 8R units but I bought new 16R poly phrams for them to suit the xover design.Brett... which B&C compression drivers are you using?
I can't make out the model number in the photo.
I know. I bought the drivers from Nick with the flares and mids. They turn up regularly secondhand though and the phrams are available.Sadly, both the DE25-16 and DE25-8 are now discontinued, and replaced by the DE250 series.
Looking good, Dave! I have my blanks sanded, and I'm still weighing the pros and cons of adding the mids or not. Nick said in one of his posts that he actually plans to do just the compression driver on his own system for a 1khz and higher horn. That certainly is very appealing to keep the cost and complexity down. However, I do have Klipshorn bass bins that would mate really nicely to a 300 Hz horn. If I build them up and THEN decide to add the mids, it will be a lot tougher to mill the cutouts.
I was thinking of how to measure these, and I may be able to do it. Tom D said in one of his posts that you absolutely must measure acoustic phase in order to have any hope of getting the crossover right. When I use Soundeasy for measurements, it does take acoustic phase up to the limit of the soundcard cutoff, and then I perform a Hilbert transform and tail correct to extend the amplitude and phase response beyond the 22khz boundary of my current soundcard. Down at 1khz, the measured phase may be good enough. Or maybe Tom was implying that the phase of the mids being compressed through the holes is tough to measure. I may ask on diyaudio, and see if I can get Tom to respond and clarify. Or if there are any Soundeasy users here, please give me your thoughts.
If we do get enough people for a minimum buy on the Misco drivers, I may be interested in that as well. Great thread!
Markus
Horns have never impressed me either, but I share similar tastes in speakers with Dave, so I'd like to see where this goes.
Prior to acquiring the mids, I'll be honest and say that the thought crossed my mind to just make it a 2 way. A few things stopped me from moving in that direction, however. If going with a 2 way, I'd probably take one of three paths. Clone a TAD TH4001 (Because they look damn cool), make a oblate spheroidal horn a la Gedlee Summa (I have heard his and they are one of the best speakers ever built, IMO), or lastly, build or use a horn with a 90x40 coverage pattern to allow the center to center spacing to be tighter between the horn and the TD15M. While I'm sure the unity horn would perform very well as a two way, there are probably better profiles to work with. Conical horns tend to sound pretty good, but it's been proven to me that there are better profiles to use, especially in a typical two way.
The Klipschorn bottom end is an intriguing combination, although you'd probably end up having to pad it down after you worked out the proper CD compensation for the unity. I'm expecting it to be about a 100dB 1w/1m system. My original plan was to use a pair of TD15Ms in an MTM config but finances put a damper on that plan and one pair of TD15Ms is as good as sold to squidward. Unless things turnaround and I can convince him something is better and that he wants to back out.
Measuring them is a concern of mine, as well. I figure the easiest route is to take Danley's crossover design and build them exactly to plans utilizing the same drivers. I suspect soundeasy will be capable of doing what you need it to do, I'm curious if HOLMimpulse will, though.
Check w/ Patrick Bateman at DIYaudio, he claims to have a number of the misco drivers. Might be worth seeing if they are cheaper than Nick.
Center to Center is the concern that is making me consider the mids. Although Geddes' Abbeys and even the Summas must be stretching things a bit. I think I remember reading that he valued getting the woofer's off axis response to match the horn's response as a higher priority. If his waveguides weren't so spendy I would seriously consider going that route. Maybe my summer project will be calculating the right profile and turning an oblate spheroid on the lathe.
I'm still kicking ideas around for the bottom end. The khorns would indeed need padded or biamped to match the Unity. I was also looking the Selenium 15PW3 or similar 15 inch woofers.
Where are you getting the reticulated foam? I've done some surfing trying to find a big 'ol block of 30 ppm foam, and I can only find thin sheets.
Markus
I bought a 2" thick sheet of reticulated foam from the foam factory on hall road, near Gratiot. I was planning on making layers.
Terry, I haven't heard Patrick's system, obviously, but I have seen the threads. I'd like to hear how it compared to some of the better systems in cars that I have heard. A few friends of mine were sound quality champs at national level events and they were certainly nice installs.
The issue with the center to center spacing is the off axis nulls that are caused. The farther about the center to center spacing, the narrower the vertical window becomes. It's a concern, just not a primary one in my experience. If I could avoid it while achieving other goals, I'd try to. The Summas were designed to be listened to off axis, and have been marketed as such if you call what Earl does, marketing. There is at least one fairly prominent horn system designer that considers the nulls in the Summas as being a significant flaw in the design but in my experience you have to really want to make it an issue with intentionally horrendous placement.
Terry, I'm very curious to hear your opinion of the Summas. IIRC, they were probably not set up nearly as ideally as Earl's in his home, but I'm curious if any of the magic I heard came through.
