Checking back in to share a new experience with this cartridge. Last night I decided to try it out again on a DC motor modified AR-XA with Rega RB-250 arm. Previously I had only ever tried it on stock MM phono stages with 47k loading. Should be good to go, but never really dug the cartridge so would always eventually change it out. Always sounded anemic. Good sparkle, but something missing. I got it as NOS in a trade and probably only ever put 100-150 hours on it in total.
Well, now have a vintage Hitachi integrated amp with adjustable impedance loading on the MM stage (100k, 47k, 22k, and 100Ω), and a MC input with a fixed 100Ω load. The phono stage has 40db gain with an additional 20db in MC mode. Chucked it up and went to town playing with different settings.
At 2mv of output the cartridge definitely needed to be cranked up more than I was used to. But, the noise floor on this amp was still low enough that it wasn't a problem. Normal listening with a 5mv MM cartridge would be between 9 and 11:00 on the dial. Now pushing 12-1:00 + to achieve the same levels but it still sounded pretty thin and not satisfying.
Carefully tried the MC input at 60db gain (worried I might overload the phono stage) and the gain kind of hit just about the right spot. But somewhat changed the character of the sound and not really for the better. The top end was virtually absent. My understanding is that, yeah, at 60db gain 2mv would be too much for the phono stage. However, the combination of too low of an input impedance actually lowering the gain somewhat, and the headroom of the phono stage means it shouldn't really be a problem. (spec'd overload for this phono stage is 300mv MM, and 30mv MC)
Playing around with the input impedance of the MM input revealed some interesting changes. Dropping from 47k down 22k seamed to smooth it out some, but dropping to 100Ω on the MM seriously cut the gain and rolled off the top end somewhat. If I cranked it in 100Ω MM the sound was actually getting a lot fuller sounding. Just not enough gain to be practical.
So, here's where it got interesting. I dragged out my SUT (vintage Harmon Kardon XT-3 mic transformers) and set it for 1:10 step up ratio. BAM! Totally transformed this cartridge. Suddenly this thing is so musical it's not even funny. Very low noise floor. Details for days. Beautiful mid-range that I've never heard from this cart. Just the slightest hint of bass bloat, but it does dig deep. So far everything I've thrown at it from Rickie Lee Jones, to Rush, to Steely Dan, to Black Sabbath, to Queen sounds fantastic.
But wait, using a SUT with a HOMC is heresy isn't it?
By my calcs; 1:10 step of ratio on the 47k setting means I have an actual input impedance of 470Ω. If I follow the specs for the original Benz Micro Silver this would be approx. 4x times the internal impedance of 120Ω. When I switch between inputs the nominal volume seems to very closely match my tuner and vintage Magnavox CD player (both of which I believe output 1.5v), with indicates that the gain out of the phono stage is just about right for the preamp section.
I seem to have hit the sweet spot and am currently enamored of this cartridge. So glad I never sold it. Of course, YMMV but I now think that with some HOMC there is more to them than just slapping them on a standard 47k MM phono stage. Again, if we look at the original specs for the early Benz Micro the recommended loading is >200Ω - 47kΩ. So, that means just plugging it into a stock MM phono input puts that cart at the top range of acceptable input impedance. No wonder it sounded anemic to me.
http://www.tnt-audio.com/sorgenti/benz_micro_silver_e.html
