OK . . . here's my approach on this, so y'all can enlighten me. Hopefully this 70 year-old hack can
still learn a few things, although I know I ain't the brightest bulb on the tree.
Bear with me . . .
A good client sent me an SP3 to work on -- says it has an imbalance problem; wires have been cut; and many of Curcio's mods were done to the unit, but not the full magilla. He reported that the unit makes a lot of noise and vibrates the speaker cones (not entirely sure of the frequency, whether it is subsonics or something else.). The PS can caps are original.
My friend Dave G. has an SP3 and he's very happy with it. I asked him if he did any mods, and he said he changed the volume control to an ALPS (500K) because the original didn't track well, and added a resistor or two for an imbalance with the bass control, IIRC. Otherwise it's stock. He's pretty fussy about sound and he assesses performance of most things using test gear. I conclude the
stock SP3 is capable of fine performance -- at least enough to impress Dave.
I unbox and open the unit and the Sprague Orange Drops pop out like plague buboes. WTF was the modifier thinking? Not only do they look bad, they aren't affixed very well, as I noted before (they weren't part of the Curcio mods). So, seeing that the PS caps are original, and noting cut wires (among the various other mods like battery-cable jumpers [a little hyperbole never hurt anyone, right?] I decided not to power it up in that condition.
Having zero faith in Curcio's "improvements", I thought the best approach would be to bring the unit back to stock and
then troubleshoot any problems, in case the mods caused any of them.
Given that: a) Dave had a problem with the volume control; b) the client had a problem with channel imbalance; c) the volume pot gets the most use of any of them; d) ARC sells a replacement kit for the original control, and e) the ALPS is considered an upgrade by some, I decided to locate and order a replacement just for that control, in advance of powering the unit. Was that bad judgement? I let the customer decide whether he wanted the ALPS or the original pot if I reinstalled it and it worked, and he chose the ALPS.
I like to think I have good reasons for doing things, but sometimes I do things heuristically and other times "play the odds."
For example, when I am recapping a piece of gear, I often just "shotgun" the project and replace them all without testing. Other times I'll check ESR and capacity before I swap one out. Today I repaired a Marantz MA6100 SS mono amplifier . . . almost
every one of the small caps tested bad - I checked each with an ESR meter, as well as the replacement caps which is time-consuming. I did the same for a 2nd unit . . . the smarter thing would have been to just replace and not check unit #2. (The bad caps were almost all Elna brand . . . I've since revised my opinion of their quality over time).
Not all mods are good and not all are bad. The only way to really know is to do empirical testing. Which I am guilty of rarely doing.
In addition to restoring the original circuity, I also made some improvements in the SP3 . . . like replacing the cans; many carbon-comp resistors; and jettisoning the battery cables. I'll lube the controls and then give it a good test and listen.
After I started the thread that the client clarified (or maybe it was only after that I
heard what he might have already told me) that he believed the volume control wasn't the culprit for the channel imbalance, and he didn't think the unit had much actual usage, so the parts that usually wear out probably haven't. Had I absorbed that
ab initio, my approach might have varied a tad. But then maybe not.
I'll know more once I get everything installed and the testing begins . . .
