Yup, and if you'll stick with me for a bit, we'll get you substantially closer to the music, and both of us learn in the process.
You'll need three things:
1) The Radio Shack digital SPL meter you've been threatening to purchase. Mine's model #33-2055, which may still be current. We're gonna use it in ways nobody's thought of. ~$50
2) Four plumbers' test plugs from the hardware store, ~$3 apiece. Check the internal diameter of the ports on your 4311s. Mine are just under 3", and the 3" ones fit nicely:
http://audioheritage.org/vbulletin/showthread.php?p=122946#post122946
They're a thick rubber washer that gets expanded by squeezing between two metal plates as the wingnut is tightened. They do not damage the ports.
Get a small can of silicone or teflon dry lube spray while you're there also. To make the plugs operate more smoothly and easily, disassemble the plugs and spray both sides of the rubber washers to reduce the friction between them and the metal plates. Clean it off the circumference after reassembly, tho. That you want to "grab" in the ports so you can tighten. Spray the "inside" of the metal plates too.
3) Allman Brothers "Live at Fillmore East." :huge:
Background: 4311 was the less-expensive version of L100 initially sold to studios through pro (as opposed to consumer) distribution. It is a nearfield "control" (not "studio") monitor intended to be mounted on the console, away from walls (boundaries), essentially in the engineer's face. That's why it's configured "upside-down."
Boundaries enhance the bass response. There being none in the intended use, the bass was artificially "boosted" in the design. See the response curve for 4311 below. Do you understand that curve? I'll explain it, if not.
Installed near walls and/or floor boundries as you have them, the already boomy bass gets further accentuated. Stacking two pair adds even more through "mutual coupling" of the woofers, overpowering the balance.
You like bass. That's fine, but this is bad, fake, adulterated bass when used in conventional installations. We can make it good bass, and I'll show you how. Let me know when you've got the "stuff." :yes:
